parts list for top end - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > parts list for top end
PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete The Jeep Forum Discount is ON!
Unread 07-11-2015, 11:12 PM   #1
tjcustomranger
I am trying to put together a parts list so i can start gathering parts for when i get new heads...
I will be doing new intake, plenum, head, and exhaust gaskets.
Valve cover gaskets are pretty much new still. I already did the aluminum plenum swap just redoing the gaskets while its out...
Going to do the bypass hose again as well and replace and old gose clamps. A new t stat is on the list because i didnt do it during plenum....
The heads will come totally assembled with hardened ush rods....
Should lifters and cam be done? As well as cam bearings?
If i do the cam i want to upgrade while im in there since the heads will be upgraded...
What cam can i run with obd1 that will cooperate?
I will be pulling the engine to do the cam if i do it.. i may also change out the tranny to one with a nice shift kit...
So my list:
Bypass hose
Gaskets
Tstat
Pcv oil catch
Radiator
Heads (obviously)
Head bolts
Timing chain/gears
Then maybe
Cam
Bearings
Lifters
What else?
tjcustomranger is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 06:39 PM   #2
tjcustomranger
Anybody
