Parts Cleaner? - JeepForum.com
post #1 of 7 Old 04-17-2013, 10:41 AM Thread Starter
JeepBeats96JGC
Parts Cleaner?
So, im changing the head gasket on my girlfriends 98 I6 and i want to clean the valve cover and head inside and out. Should i just use a degreaser or is there something stronger/better to use?
JeepBeats96JGC is offline
post #2 of 7 Old 04-17-2013, 11:06 AM
Candymancan
Get some wearever brake cleaner from the auto parts store.. Its like $3 a can grab like 3 cans or something... Works great for cleaning anything oily... It cleaned my intake manifold easily with no scrubbing yesturday when i took it apart. I use that stuff all the time and it evaporates fast. You can use that sprayed on a rag as well to clean the headgasket surface of any oils from your bodys natural oil on your fingers to the motor oil.. I did that to clean the gasket surface on my 5.9 for my intake manifold after scraping the old gasket off
http://www.google.com/imgres?sa=X&tb...5&tx=92&ty=105
Candymancan is offline
post #3 of 7 Old 04-17-2013, 11:08 AM
kensnelling
I've also had good luck using oven cleaner.
Ken
kensnelling is offline
post #4 of 7 Old 04-17-2013, 11:10 AM Thread Starter
JeepBeats96JGC
Awesome, ill try it. Thanks!
post #5 of 7 Old 04-17-2013, 11:16 AM
Candymancan
Yea np, i love that stuff. I use it for everything, cleaning the gears in the differentials when i change the gear oil, to cleaning heavy oily grease on the engine to spraying it on a rag and cleaning gasket surfaces of oil..
post #6 of 7 Old 04-17-2013, 12:25 PM
Uniblurb
Uniblurb's Avatar
Yep Candymancan, and I use the same Wearever brake cleaner on everything. Actually I'll buy whatever brake cleaner is on sale and right now the "CRC Brakleen" is on sale at $3.50 vs $4 for the Wearever at Advance.
I spoke with a real good Pematex rep a couple months ago and he recommended using a hair dryer or heat gun to bring the oil to the surface where the gasket mates. Then use rubbing/isopropyl alcohol on a rag to clean the oil off. But we were talking about rear differential covers where you're using one of their gasket makers for best adhesion instead of using a gasket. Probably not necessary on most surfaces but just thought I'd pass it along.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
Uniblurb is offline
post #7 of 7 Old 04-17-2013, 07:38 PM
Candymancan
You can also use acetone to clean gasket surfaces with a rag That stuff is super strong... so dont get it on anything plastic.. or paint.. or itll melt it quickly lol
