Part time and Full Time 4WD Difference - JeepForum.com
post #1 of 13 Old 02-21-2003, 06:31 PM Thread Starter
Igorot_Jeeper
Can someone please tell me the difference between the two. I want to know how they function differently from one another and what is going on with my jeep when I use either of them. I also want to know when should I use either of them. The manual says part time 4wd is for slippery surfaces and full time 4wd is for all surfaces, can someone add to that. Thanks in advance.
Igorot_Jeeper is offline
post #2 of 13 Old 02-22-2003, 02:37 AM
ChrisinVA
Ok, here's the skinny.
Part time locks the front and rear driveshafts together. Basically this gives you '2 wheel' drive...one front, one rear. If you were to put the two right wheels on teflon, they would spin and get you nowhere.
Full Time is a little different, depending on what guts you have in the transfer case. Let's say you have the Selec-Trac from the very first ZJ's with the 4.0. Those were what's called an 'open differential', meaning all 4 wheels are given 25% of the available engine torque, until one wheel slips. Then that one wheel gets 100% torque, and spins, getting you nowhere. This function is nice because it *does* take more to break loose a wheel with 25% than 50% like with rear wheel drive.
The later models with the V8's, etc took it a step further and added what's called a 'viscous clutch' to the transfer case. What this does (when functioning) is sends power "from the wheel that slips to the wheel that grips" ala Subaru, etc. Unfortunately, Chrysler felt it necessary to delete the PT function except for the low range which locks the axles together.
Now, when to use each. Full Time can/should be used all the time. Period. Dry/wet/snowy..whatever.
Part Time can be used when the going gets hairy enough that FT just isn't cutting it, like offroading or snow/ice. It can also be used in heavy rain, despite what others may say. Do *not* however have it engaged on dry pavement, especially when turning. Wanna see aluminum explode?
Hopefully this helps.
ChrisinVA is offline
post #3 of 13 Old 12-14-2014, 10:30 AM
blancawelder
When I put my 1990 jeep Cherokee in "part time" 4x4 and turn the Jeep, I get the "bucking" reaction. In "full time" 4x4 turning is easy and the wheels are allowed to slip a little.
basically Chrysler doesn't know the difference between part time and full time. Even the placard on the drivers visor states, "Part time for loose gravel or snow, do NOT use on hard surfaces. Full time for ALL road surfaces".
blancawelder is offline
post #4 of 13 Old 12-14-2014, 12:03 PM
Mickey_D
The "Part Time" and "Full Time" are descriptions of when to use them, not their function.
Part Time - use it part of the time, like on snow/ice or when wheeling. Not to be used all the time.
Full Time - can be used under all driving conditions. Can be used all the time.
Please remember that when the ZJ came out they were most likely targeted at soccer moms and business execs. They were most definitely NOT aimed at off road enthusiasts. If they were aimed at us, they wouldn't have A/C, cruise control, power windows, alarm systems, leather interiors. They would look like a WWII era Willys MB.
Now saying that, try to think like a soccer mom. She's not going to be thinking, "oh, part time means the drive shafts will not bind up and grenade the planetary gears in the differential because the system is only using four wheel drive part of the time.". Nope, she's gonna be thinking, "oh part time means I should only use it part of the time".
Gotta dumb instructions down to the lowest common denominator. You're over thinking it if you think part time means it's only engaged part of the time...
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #5 of 13 Old 12-14-2014, 02:24 PM
kg6mov
Hears the voices
kg6mov's Avatar
11 years dead! 11 years! Give me a break.
Your only post on this forum is to revive an 11 year dead thread about a vehicle you don't have?
kg6mov is offline
post #6 of 13 Old 12-15-2014, 04:32 AM
GRAFIK_ZJ
Bahaha GET EM!!
GRAFIK_ZJ is offline
post #7 of 13 Old 12-15-2014, 05:18 AM
PolkaPower
I'm glad we are finally figuring this out.
PolkaPower is offline
post #8 of 13 Old 12-16-2014, 09:05 AM
blancawelder
30 years ago, I had a 1948 CJ-2A, 4 cylinder "Go Devil" engine, 3 spd, 2 spd xfer case, 5.38:1 gears. I could idle up steep 4x4 trails and even get out and walk beside the Jeep.
Every 4 wheel drive I owned after the '48, (except my Cherokee), Ford, Chevy, Toyota, Part Time means Part Time and Full Time Means Full Time. My Cherokee is the first Chrysler I've ever owned. Are the new Jeeps just as confusing?
I take my Cherokee into some rugged country and I'm beating the crap out of it. Gonna start looking for another old Willy's CJ for the high Country and use my Cherokee for flat land driving.
post #9 of 13 Old 12-16-2014, 10:42 AM
superj
the new wranglers suck. they are worse. i cannot comment on the cherokees and stuff that are new, i wont get one.
i like the 80s and 90s jeeps (wranglers, cherokees, grand cherokees, comanches) because they were nimble and comfortable with tons of power. we just sold our four door wrangler because it was huge and plastic, got terrible gas mileage, and had zero power. it was a pain to work on, also. i will take a jeep any day of the week for anything, as long as its older then 2006 and normally drives in rear wheel drive.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #10 of 13 Old 06-09-2017, 06:08 PM
jhink92
I'm just gonna quote this for no reason at all just to frustrate kg <3
Love you guys! Haha
jhink92 is offline
post #11 of 13 Old 06-09-2017, 06:26 PM
kg6mov
Hears the voices
kg6mov's Avatar
Love you guys! Haha
I'm going to buy every red zj rear hatch within 100 miles of you.
kg6mov is offline
post #12 of 13 Old 06-09-2017, 06:43 PM
jhink92
I'm just gonna quote this for no reason at all just to frustrate kg &lt;3
Love you guys! Haha
You know, that would be messed up and all, but sadly my jeep is actually ford red..... So gotta repaint it anyways ?? dang P.O just had to have the thing repainted!!!!! Hmph.
Oh yeah, it's a single stage pearl red metallic. One of the single handedly hardest paints to lay down without looking like crap.
jhink92 is offline
post #13 of 13 Old 06-09-2017, 06:43 PM
jhink92
Love you guys! Haha
But love you too big fella <3
jhink92 is offline
Part Time or Full Time? cweb ZJ Grand Cherokee Forum 2 02-19-2008 08:24 AM
Smoking Diffs? Part Time/Full Time? azcoyote ZJ Grand Cherokee Forum 30 04-01-2007 07:29 PM
GC Part-Time and Full-Time 4x4? What's the difference? rockon1202 ZJ Grand Cherokee Forum 14 03-04-2005 03:19 PM
part time 4wd and full time 4wd Wah WJ Grand Cherokee Forum 2 03-20-2003 01:46 AM
Full time 4wd to part time conversion? yourNME13 ZJ Grand Cherokee Forum 6 04-20-2002 11:49 AM
