Parking lights not working? - JeepForum.com
post #1 of 14 Old 05-04-2013, 10:09 PM Thread Starter
Haleyrz
I feel like an idiot that I'm not getting this one, so here it is:
I discovered a missing bulb in my passenger side, bottom corner (the 194A). So I installed one. Didnt turn them on to test since it was daylight. A couple hours later I turned them on after changing my radiator hoses. Well, my corner parking lights front and back don't work. I assumed its a fuse, but I can't find one in the kick panel or under hood. It's a 1998 2wd Laredo. Am I totally overlooking this?
1998 ZJ Laredo, 4.0L, 2WD, it's boring
Haleyrz is offline
post #2 of 14 Old 05-04-2013, 10:53 PM
KoreaZJ
1994 ZJ
Fuse #17 (15 amp) located in Junction Block, passenger side kick panel.
Park Lamp Relay located in Junction Block, passenger side kick panel.
KoreaZJ is offline
post #3 of 14 Old 05-05-2013, 03:57 PM Thread Starter
Haleyrz
Cool thanks man. Here's a pic of my fuse panel diagram. Cuz my #17 is not blown. I suppose I'll pick up a relay today at work and give that a try.
Haleyrz is offline
post #4 of 14 Old 05-05-2013, 06:01 PM Thread Starter
Haleyrz
Alright. No blown fuses, and I tried a new relay at work and still no parking lights
Haleyrz is offline
post #5 of 14 Old 05-06-2013, 01:16 AM
KoreaZJ
1994 ZJ
Pull Park Lamp Relay.
Use tester or meter, check for +12v on relay Pins#30 & #86. (from Fuse#17) (key ON or OFF)
Test park lamps by bypassing relay... jumper relay socket Pins#30 & #87.
KoreaZJ is offline
post #6 of 14 Old 06-11-2013, 11:47 AM
MightyFez
Did this issue ever get resolved? I am wondering because I am having the same problem, no parking lights. Looked at fuse 17 (15amp) and it is fine.
Is the relay panel referred to by KoreaZJ under the hood?
MightyFez is offline
post #7 of 14 Old 06-11-2013, 03:36 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Fez,look at Korea's first post, duh.
Originally Posted by HighLonesome
coralman is offline
post #8 of 14 Old 06-16-2013, 12:59 PM
BGL
So was this resolved? I need to fix the parking lights ASAP and I dot understand why they aren't working.
BGL is offline
post #9 of 14 Old 06-17-2013, 01:41 PM
MightyFez
Doh! Missed that!
The Mighty Fez
1998 ZJ 4.0L I6 - Stock (for now)
post #10 of 14 Old 06-17-2013, 01:43 PM
MightyFez
I'm right there with ya, wondering if this even got resolved.
The Mighty Fez
post #11 of 14 Old 06-17-2013, 01:48 PM
BGL
Like seriously...a 97 jeep grand cherokee Laredo aka ZJ has two fuse boxes( one under the good by coolant, the other by the passenger kick panel) neither saying where the parking relay fuse would be.
BGL
BGL is offline
post #12 of 14 Old 07-08-2017, 12:38 PM
ChrisD93
I had exact same issue n my 95 ZJ changed 17 even tho good. Changed relay it looked a bit funny but turned out also good. So I got my tester and puller and went through every single fuse. Third to last was 12 and was burnt changed it and entire problem solved. Had it on my 93 YJ too but on it the fuse is label from the factory unlike my Cherokee which I also has no owners manual but that wouldn't have helped because they list it as 17 any
ChrisD93 is offline
post #13 of 14 Old 07-08-2017, 12:43 PM
ChrisD93
Also on ZJs there's a relay panel in the glove box 3 screws and you can access it. Everyone says there's two pannels. One under good and one on passenger end side of dash. But the other relay pannel is in the globe box.
ChrisD93 is offline
post #14 of 14 Old 07-08-2017, 01:07 PM
kg6mov
Hears the voices
kg6mov's Avatar
You're confusing the first and second gen, the second gen in this thread it would be fuse #17 in the passenger kick panel. On a first gen like yours it is fuse 12 in the glovebox.
kg6mov is offline
