Parking brake lever - JeepForum.com
post #1 of 5 Old 11-08-2013, 10:38 PM Thread Starter
OverlandZJ
Parking brake lever
I'm swapping the ZJ discs to my XJ Dana 44.. that's been modified to bolt in my ZJ.
These parking brake lever pieces should pivot on each other correct? Mine seems frozen by rust.. just free up and add a touch of grease?
OverlandZJ is offline
post #2 of 5 Old 11-09-2013, 11:24 AM
Gazang
Overland,
Yes they are (supposed to be) 2 pivoting pieces. Turns out they like to rust weld themselves into a single inoperable unit.
Check out this link:
http://www.jeepforum.com/forum/f13/z...e-post-454677/
Good writeup on R&R on zj e-brakes.
Definitely try to free them up first (to save the $), but they can up and break when trying to unfreeze.
Be sure to re-install with a good dose of grease and prob. check adjuster bolts too as they can go the rust route as well.
Good luck
JS
Gazang is offline
post #3 of 5 Old 11-09-2013, 11:29 AM Thread Starter
OverlandZJ
Thank You! I'll check that link out a bit later.. taking a break from grinding on these caliper brackets.
post #4 of 5 Old 11-11-2013, 09:48 AM Thread Starter
OverlandZJ
Success... thanks again, was able to free them up and hit with a wire wheel. I'll grease them good since they live in the rubber boots.
post #5 of 5 Old 11-11-2013, 10:30 PM
Gazang
Nice work. Always cool to fix your own stuff!
JS
Gazang is offline
