"Park" won't engage - JeepForum.com
post #1 of 21 Old 08-07-2012, 02:03 PM Thread Starter
htcrkjak
"Park" won't engage
When my '98 ZJ is in Park, it tends to move. Park doesn't fully engage. Any ideas?
Thanks
htcrkjak is offline
post #2 of 21 Old 08-07-2012, 02:05 PM
sevenscrew
is the gear shifter adjusted underneath on the driver side of the trans? dont know much about park not engaging fully tho
1997 Limited 5.2L Nelly - SOLD
1997 Limited 5.2L - new project
sevenscrew is offline
post #3 of 21 Old 08-07-2012, 02:09 PM
FAlfani81
Are you missing your front drive shaft?
FAlfani81 is offline
post #4 of 21 Old 08-07-2012, 02:29 PM
ajmorell
ajmorell's Avatar
Whether or not the front driveshaft is there wouldn't matter even if he had a 249. The 96+ don't roll w/out it like the 93-95 do. I'm wondering if the parking pawl is broken.
ajmorell is offline
post #5 of 21 Old 08-07-2012, 02:31 PM
FAlfani81
Didn't know that! Good to know
post #6 of 21 Old 08-08-2012, 02:29 AM
95cherokee318
the VC will allow it to roll if its bad. and it probably is lol ive seen this happen not just on mine when it had the 249, but a friends that was a 98 zj and it was the VC.
my advise... do the 242 or the 231 swap, youll like either one more.
95cherokee318 is offline
post #7 of 21 Old 08-08-2012, 03:12 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
There is a tsb in the FAQ about the shifter detent also.
http://www.jeepforum.com/forum/f13/c...-faqs-2863665/
Originally Posted by HighLonesome
coralman is offline
post #8 of 21 Old 08-09-2012, 06:31 PM Thread Starter
htcrkjak
Vc?
I am a bit ignorant. What is a VC.
htcrkjak is offline
post #9 of 21 Old 08-09-2012, 06:41 PM
ajmorell
ajmorell's Avatar
viscous coupler, it's part of the 249 transfer case
ajmorell is offline
post #10 of 21 Old 08-09-2012, 06:54 PM
CatSplat
1994 ZJ
I honestly don't see how that's possible. VCs fail in the "locked" mode and are essentially in 4PT. How would that allow the vehicle to roll with the parking pawl engaged?
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline
post #11 of 21 Old 08-09-2012, 07:57 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
doesn't work like that at all actually
ratmonkey is offline
post #12 of 21 Old 08-09-2012, 07:58 PM
FAlfani81
When mine went bad it would only turn "4PT" when it was warmed up. You could literally hear it unbind as it cooled down with random *BUUNG* sounds. After I pulled the driveshaft it would stay put when parked until it cooled down.
post #13 of 21 Old 08-09-2012, 09:24 PM
95cherokee318
it will roll, it depends on what happens internally to the VC, you could actually turn mine by hand when i took it out, it was ridiculous....
even when the pawl is locked in, the power is distributed through the transfer case via the VC, and if the VC actually somehow had a hole in it that wouldnt allow the fluid to build pressure, your jeep wouldnt move at all, or very little.
I'm not trying to disprove anyone, these viscous couplings were a mistake made by new process gear. nice when their new, but worthless when they go, and they dont really last up to par for our jeeps, the symtoms of a failed VC vary, but are always doing the same things, im so glad i swapped my transfer case lol
post #14 of 21 Old 08-10-2012, 10:16 AM
CatSplat
1994 ZJ
Precisely, having the removed front drive shaft was what caused it to roll, not the state of the VC. Any '93-'95 249 will roll in Park with the front DS removed.
The Jeep of Theseus
CatSplat is offline
post #15 of 21 Old 08-10-2012, 11:45 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
93-95 will roll no matter if it's good or bad when you pull a shaft, axle or drive. 96+ that problem was corrected and it can't roll in park with the rear shaft in.
It only fails one way, bound up when heated.
The reason the early ones fail so regularly is because they are in use 100% of the time. The later ones, and the way Subaru and other manufacturers use them, last twice as long because they aren't putting all the driveline power through them.
The op does NOT have a case that will allow it to roll in park unless someone put an early one in to spite him.
Let's get back on topic.
Also, how fast if it rolling? Creeping, like it's in neutral? what?
Sunroof: should it "park" closed, or do you have to toggle it perfectly closed? StellaTheZJ ZJ Grand Cherokee Forum 4 12-19-2010 01:23 AM
Message "vehicle not in park" kiesha WK Grand Cherokee & XK Commander Forum 4 11-01-2008 09:30 PM
Loud "Squeak" when shifting from park to reverse JTim ZJ Grand Cherokee Forum 1 09-04-2006 10:23 AM
"Park" is not quite what I thought it would be... crozzer ZJ Grand Cherokee Forum 18 12-31-2005 12:32 AM
Chirping/Squeaking only when in "Park" or "N" 3D-Dave ZJ Grand Cherokee Forum 1 05-01-2004 03:05 PM
