Parasitic battery drain, but... -
Go Back > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Parasitic battery drain, but...
Santa Kolak Announces: Bilstein Holiday Sale! Lowest prici20 percent off Seward LED at JeepHut starts tonightFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 11-02-2015, 06:41 PM   #1
I've had this problem for over the past month or so, and I've just been pulling fuse #7 to stop the drain. I've read into a lot of forums and discussions on this matter and so I proceeded on removing the panels from the lift gate and I pulled the two latch plugs and the rear wiper motor plug, and waited a few minutes and my test light never showed any sign of change. I proceeded to just pull every plug on the lift gate to see if that might help, but no, it still did not.
Before moving on to check the BCM, I went and checked the factory power amplifier and no change. Went up to the dash, pulled the security light/auto headlight sensor, and no change. Next I pulled the instrument cluster out and, surprise, no change.
Finally, I went and pulled the black plug first, waited, and no change, then finally, I pulled the white plug and the test light, within a couple of seconds, went out, and the light turned back on with much less power.
I found a picture on what all the pins connect to, but I don't have the time to go and pull pins one by one to figure it out, if anyone has any ideas on what it could be, it would be much appreciated.
jhp0802 is offline   Reply With Quote Quick reply to this message
In order to be able to post messages on the forums, you must first register.
Jeep, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. is not in any way associated with Jeep or the Chrysler Corp.
