panel lamp driver voltage range? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > panel lamp driver voltage range?
1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,Zone Offroad Body and Suspension Lift Kits, Brackets, Disc
Unread 03-01-2014, 04:38 PM   #1
coralman
its the beam Jim
coralman's Avatar
Anyone know the panel lamp driver voltage range?
http://www.jeepforum.com/forum/f13/c...-faqs-2863665/
coralman is online now   Reply With Quote Quick reply to this message
Unread 03-02-2014, 07:45 AM   #2
ZeeJay1997
IDK the voltage, but I know this; on the ZJs with a BCM, it's pulse-width modulated.
I'm going to install a VIC today so I'll put a meter on the ash tray light. It is on the same circuit as the inst lights.
ZeeJay1997 is offline   Reply With Quote Quick reply to this message
Unread 03-02-2014, 08:48 AM   #3
coralman
its the beam Jim
coralman's Avatar
Ok, take me to school on that one. I think the WJ heater or radiator fan is pulse width modulated. I take that to mean that rather than a constant voltage it is pulsed at varying band widths to maintain speed, light intensity. I assume its a more definitive way of fine tuning output? IDK.
Unread 03-02-2014, 10:11 AM   #4
ZeeJay1997
i have no idea why they would modulate a lamp voltage, but it must be VHF because the meter reads battery voltage on the orange wire to the lighter halo.
Unread 03-02-2014, 01:49 PM   #5
coralman
its the beam Jim
coralman's Avatar
Hey battery volts is battery volts. Thanks my friend! Did the Vic work?
Unread 03-02-2014, 01:57 PM   #6
ZeeJay1997
yes, it worked like a charm. And it exhibited behavior I never noticed on the first one. when i press a button with the key off, it shows the time and date for a few seconds. I swear my old one didnt do that.
Unread 03-02-2014, 04:21 PM   #7
coralman
its the beam Jim
coralman's Avatar
OK here comes the freaky part. I spent pretty much the whole day cleaning mine,inside and out. I was finally about done and was using a plastic screen wipe to clean the VIC screen and pushed a button while doing it. It did the same thing and I had never seen that before either,lol. Didn't know Chrysler had a subliminal function included.
Unread 03-02-2014, 05:43 PM   #8
ZeeJay1997
i guess they thought you may be sitting somewhere without your keys and need to know the time and date.
