Paint question - JeepForum.com
post #1 of 10 Old 09-19-2017, 10:36 AM Thread Starter
BorderWalker
Paint question
So my wipers are flaking paint badly. Gonna take the arms off and give them a repaint to freshen the look with some Rattlecan black.
My question is, can I use the same rattlecan for my roof rack? Or would I be better with a different type of paint to repaint my faded rack?
Thanks guys.
._________.ooooo.
/ŻŻŻ|ŻŻ|ŻŻ\ŻŻŻŻŻ\,____
L/ŻŻ\\__|__|"/ŻŻŻ\=llllll=\
_(Ż))===)).....(Ż))===))Ż
BorderWalker is offline
post #2 of 10 Old 09-19-2017, 02:45 PM
kg6mov
Hears the voices
kg6mov's Avatar
Same thing should work fine for both. It's all in the prep.
kg6mov is offline
post #3 of 10 Old 09-19-2017, 02:53 PM Thread Starter
BorderWalker
Cool, thanks!
._________.ooooo.
post #4 of 10 Old 09-19-2017, 03:09 PM
wingless
wingless's Avatar
1994 ZJ
Flat, satin or semi-gloss for wiper arms, not gloss.
wingless is offline
post #5 of 10 Old 09-19-2017, 03:11 PM
1996maroonzjf
Also, be sure to mark the location of the wiper arms before you remove them. It is a pain to try and find the correct location afterwords.
-Tim
96 4.0 Laredo, 42RE, NP242, HP30 & D35c 3.55, OME 2.5" HD Coils, Bilstein 5100s, IRO Adj. LCAs
1996maroonzjf is offline
post #6 of 10 Old 09-19-2017, 03:17 PM
PolkaPower
Scruff them up good and use an excellent 2k primer.
Sent from my GRACE using Tapatalk
PolkaPower is online now
post #7 of 10 Old 09-19-2017, 03:24 PM
wingless
wingless's Avatar
1994 ZJ
The FSM shows the arm locations for installation.
wingless is offline
post #8 of 10 Old 09-20-2017, 07:31 AM
zjosh93
There's generally a fair amount of slop in that linkage especially if the Jeep has a few miles on it. The FSM or marking the original locations will get you close but don't be surprised if you have to move it a notch or so one way or another.
Most auto parts places carry trim paint. It's a little closer to OEM trim finish than regular semi-gloss or satin. I've used it before and it works pretty well, good coverage and holds up to environmental exposure.
zjosh93 is offline
post #9 of 10 Old 09-20-2017, 07:35 AM Thread Starter
BorderWalker
Much obliged guys. This isn't the first time I've removed my wiper arms before so I know the trickiness of lining it back up.
._________.ooooo.
post #10 of 10 Old 09-20-2017, 12:40 PM
Uniblurb
Uniblurb's Avatar
Yeah BW, any mark you make on the wiper arm base to align with the stud is going to be painted over. Best to lift the wiper arm up, set it down gently, then put a couple pieces of blue painters tape on the windshield close to each side of the rubber wiper tip for aligning it back up when re-installed. Any kind of tape you can see will work.
I've used the below Rust-Oleum pro gloss black successfully on lots of parts on my Jeeps. Don't really get any sun glare off of it and the gloss part isn't real reflective for long. And when raining with the wipers going across the windshield normally sun isn't out when raining. Lol.
https://www.amazon.com/Rust-Oleum-75...ck+spray+paint
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is offline
