#1 | |
P1282 code
i found out today how to look for codes on my jeep by turning the key on/off 3 times..
code P1282 comes up for a few seconds then goes away and it says done so not sure what that means as far as the code this is what it says at WJ JEEPS.... "Fuel Pump Relay Control Circuit - An open or shorted condition detected in the fuel pump relay control circuit". what does this mean to the average non mechanic guy like my self..by the way i have an 01 4.0 JGC and have been having rough idle surges not to bad but there there..YES ive done a tuneup ,IAC ,throttle clean and all that... could this issue (code) be my problem
#2 |
POSSIBLE CAUSES
Fused ignition switch output ckt Fuel pump relay defective Fuel pump relay control ckt for open Fuel pump relay control ckt for short to ground Fuel pump relay wiring harness observable defect Fuel pump relay wiring harness intermittent defect PCM defective
[I]No man stands as tall as when he bends to help a child. I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day.[/I] [QUOTE]Why is there a fish finder in your Jeep?[/QUOTE] ______0__0 /__l_l_,\____\,__ l_---l_l__l----( )jeep( ) \ \ \ \ ._(o)_)__(o)_)--o-)_) |
#3 |
i guess a shop will be able to figure this out pretty easy or is it a hit and miss thing
#4 |
Well i dont know about easy, but if you dont have much knowledge about elec then bring it to them, just write down what I provided, because that is what is wrong.
#5 |
thanks man i appreciate your help on this for sure!!
do you think this could have something to do with my surging type idle issue im having? also when it says done after the code is that normal? |
#6 |
It Could Be, and yes on the DONE part. that means that is done reading the codes. Good Luck, and no problem on the help, that is why we are here.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
