P0740 Code - TCC Circuit Malfuntion - JeepForum.com
post #1 of 14 Old 02-15-2006, 10:22 PM Thread Starter
mongerryan
Hi All,
I've had my check engine light on for a while on my 01 grand Cherokee, and I finally was able to get a OBD tool to check it. It gave me a P0740 Code - TCC Circuit Malfuntion code. From a search on this forum:
"P0740 (M)
Torq Con Clu, No RPM Drop at
Lockup
Relationship between engine and vehicle speeds
indicated failure of torque convertor clutch lock-up system
(TCC/PTU solenoid)
I'd ask here about symptoms of a bad Torque Converter."
and
It's one (or more)of, probably, three things:
- Bad torque converter (blew the lockup clutch)
- Bad lockup solenoid
- Bad wiring from the PCM to the lockup solenoid
- Very remote possibility, but possible none the less -> Bad PCM.
You *MUST* fix this before driving on the freeway, or at freeway speeds, as you can burn up your transmssion by driving at freeway speeds without the toque converter locked up.
- Oh, forgot, could be the speed sensor also, but that's a little doubtful.
If it turns out to be a bad torque converter (blown lockup clutch), the transmission will have to be taken apart and checked, as, more than likely, lockup clutch material would have made it into the tranny,
I'ld start with the wiring itself. Check to make sure that it looks ok at the electronic solenoid itself.
So...my question is...what should I do about this? Would a regular mechanic be able to take care of this, or should I take it to the service at a jeep dealership?
Anything else I should look for from this problem? Anybody else had this problem and fixed it?
Thanks ahead of time for your comments!
Ryan
mongerryan is offline
post #2 of 14 Old 02-16-2006, 05:05 AM
greasefingers
greasefingers's Avatar
1994 ZJ
I am not aware of any danger if you continue to drive this way. You will however see a drop in gas mileage. I believe your solenoid is fried.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #3 of 14 Old 02-16-2006, 05:14 AM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
I don't think you havew to take it to a dealer. A good transmission shop should be able to fix it.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #4 of 14 Old 02-27-2006, 06:07 PM
Virmagicus
Virmagicus's Avatar
Turn your overdrive off
Jeff
Virmagicus is offline
post #5 of 14 Old 02-27-2006, 11:20 PM
Ross
I just got this pcode today. It will stall if I don't keep the engine speed up. If I turn off the o/d it seems to idle but not very smooth and eventually die.
Is there anyway to get a little better handle on what is going on other than the shop?
01 TJ,33X12.5Flaken WP ATs,Winch, ARBs F&R, belly up, some armor,4.0,5spd
Ross is offline
post #6 of 14 Old 02-28-2006, 04:50 AM
greasefingers
1994 ZJ
Your VSS is bad. The PCM needs to know how fast the vehicle is traveling. Instead the PCM will use one or other sensors to try and determine the vehicle speed. Doing it this way is not accurate enough and the engine is not performing properly. Replace it and your problem should go away.
Cheers Steve
post #7 of 14 Old 02-28-2006, 08:10 AM
Ross
Tahnks for you help. Is VSS Vehicle Speed Sensor. If so I found a write up for it being changed on a 95 grand. It seems like it is the component that the speedo gear is attached to, if it is anything like the right up says. I have changed the speedo gear on my TJ and that was a 3 minute job. Do I have it right or am I heading in the wrong direction?
Another thing I have noticed. When I first start it its fine. It is revving at about 900rpm like it should but it doesn't drop in rpms when I shift into gear. After I have driving, and go to stop, the rpms will fall put it will ussally die unless I give it gas. Even if I shift into neutral or park the rpms will still drop and the vehicle will die unless I give it gas.
Thanks again for the help. It is pooring rain and the jeep is outside. I am heading for work. I shouldbe abel to get under it tonite.
Ross is offline
post #8 of 14 Old 02-28-2006, 08:28 AM
greasefingers
1994 ZJ
Yes thatís correct. However I do not know where yours is. It will either be on the tranny or the transfer case. First make sure that it is plugged in and that nothing has flown up and damaged the wires.
Cheers Steve
post #9 of 14 Old 02-28-2006, 08:33 AM
Ross
Thanks for the help, My wife is about seven and a half months pregnant and can't get in and out of my TJ very easy, becasue of the lift, and I hait leaving her with out a vehicle for very long.
Ross is offline
post #10 of 14 Old 02-28-2006, 08:53 AM
Woody
Retired back to Bowties
Woody's Avatar
1985
Grease, the WJ's don't use a VSS. They get speed from another source. I'm not sure what offhand though.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #11 of 14 Old 02-28-2006, 10:49 AM
Ross
I called the dealership. They are too different sensors it MIGHT be one measures wheel speed and the other measures transmission out put speed. I assume it is the later of the two. I am not sure were they are located on the vehicle but I am going to go to the dealer and hopefull they have a diagram I can look at.
Ross is offline
post #12 of 14 Old 02-28-2006, 11:44 AM
greasefingers
1994 ZJ
Ahh sorry if I mislead anyone here??
Cheers Steve
post #13 of 14 Old 02-28-2006, 12:19 PM
Ross
Its a different part but you lead me in the right direction. Thanks
Ross is offline
post #14 of 14 Old 03-01-2006, 02:43 PM
Ross
Went to the dealership and talked with a very helpful Mech. He said 0740 is the code for the torque converter lockup switch ( I may not have the tech name). You have to drop the pan to get to it, but should be easy to get to. I going to have it done, I am about to put my house on the market and don't need a oil stain on the garage floor.
Ross is offline
Trans over Temp light come on and P0740 code luigi120 ZJ Grand Cherokee Forum 8 11-26-2010 08:17 AM
Transmission Code P0740 stratons_yj ZJ Grand Cherokee Forum 4 01-20-2010 07:17 PM
P0740 diag code, any advice/ Torque Conv Clutch LibertyOrDeath ZJ Grand Cherokee Forum 4 07-21-2009 07:17 AM
P1757 & P0740 code- What do I need to replace? 96stroker ZJ Grand Cherokee Forum 0 06-04-2009 07:40 AM
2001 WJ 42RE P0740 Code Poor gas mileage scherisho ZJ Grand Cherokee Forum 8 12-02-2008 06:16 AM
