P0740 42RE -- Typical hwy RPM? - JeepForum.com
post #1 of 6 Old 02-24-2008, 10:23 AM Thread Starter
gmunee
I've got 01 Laredo 4.0L & 42RE that is reporting a P0740. I am trying to determine if its really slipping, or just the TCM telling the PCM to illuminate the check engine light.
I started getting the classic 1-2 shift hunts at low speed, that are likely the Governor Pressure sensor & solenoid. Thanks to this forum and Dr.Righteous on JU, I was planning on replacing those. The new P0740 has me worried.
I was hoping the the failing GPS finally threw a code to the TCM, told the PCM, then turn on the light.
How can I determine if it really the TCC slipping?
What RPM is typical at 65mph for a stock WJ 4.0L?
Any help is appreciated.
gmunee is offline
post #2 of 6 Old 02-24-2008, 10:57 AM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
nea, i cant help ya none, but hey, welcome to JF.
and where are you in norcal? i am just outside of sacramento.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #3 of 6 Old 02-24-2008, 02:36 PM
_Kyle_
_Kyle_'s Avatar
My highway RPM is just under 2500 if I remember correctly and that's at around 65-70mph.
-Kyle
1996 Grand Cherokee
2005 Wrangler Rocky Mountain Edition
RIP Troy (bigbluezj94)
_Kyle_ is offline
post #4 of 6 Old 02-24-2008, 02:42 PM
WiLieR
Depends on the rear gears. Our 99 4.0 42RE turns about 2k at 70mph with 3.55s.
99 WJ Laredo - Mine once again!
WiLieR is offline
post #5 of 6 Old 02-24-2008, 02:53 PM
indept
2K @ 65 mph (4th gear & torque locked)
2000 WJ 4.0L 42RE 242 TC
190,091 miles & counting
indept is offline
post #6 of 6 Old 02-24-2008, 07:26 PM Thread Starter
gmunee
THanks for the response.
How is one to tell when the torque is locked at fwy speed?
Thanks.
gmunee is offline
Transmission Code P0740 stratons_yj ZJ Grand Cherokee Forum 4 01-20-2010 07:17 PM
P1757 & P0740 code- What do I need to replace? 96stroker ZJ Grand Cherokee Forum 0 06-04-2009 07:40 AM
2001 WJ 42RE P0740 Code Poor gas mileage scherisho ZJ Grand Cherokee Forum 8 12-02-2008 06:16 AM
P0740 boldknight ZJ Grand Cherokee Forum 0 09-18-2006 09:06 PM
P0740 Code - TCC Circuit Malfuntion mongerryan ZJ Grand Cherokee Forum 13 03-01-2006 02:43 PM
