P0711 Trans Fluid Temperature Sensor???? - JeepForum.com
post #1 of 8 Old 03-01-2009, 11:54 AM Thread Starter
2007GC Overland
2007 WK
Hi Folks
96 GC limited 5.2 has a code of P0711 Transmission Fluid Temperature Sensor, No Temperature Rise after Start - I did search and could only find the above statement.
Does anybody know what that means or what is causing the code? When code start showing up, something is going to break or have problems.
thanks _ I apppreciate any help on this.
Bill
2007GC Overland is offline
post #2 of 8 Old 03-01-2009, 02:22 PM
tazimafied
This sounds like a failing sensor. No temp rise after start simply means the computer is not seeing the temp come up in the trans fluid which is impossible. Ask a local shop and see how involved the replacement is. You might even be able to order the part and replace it yourself in your driveway.
Because I felt like it!
tazimafied is offline
post #3 of 8 Old 03-01-2009, 03:39 PM
ZeeJay1997
The temp sensor is part of the governor pressure sensor. It's easy to replace unless you have an aversion to transmission fluid or no mechanical skills.
You have to drop the pan and take off the governor body to get to the retaining clip.
It should read 1000 ohm at around 70 degrees. On a 97 it's a violet wire, pin 1 on the center PCM plug.
Disconnect battery before checking at PCM.
Is it shifting okay?
ZeeJay1997 is offline
post #4 of 8 Old 03-02-2009, 06:41 AM Thread Starter
2007GC Overland
2007 WK
Hi ZeeJay
yes it is shifting OK - this week had to replace the CAT - it started to break a part and stop up the exhaust. Installed a new CAT, everything appears to work OK, power restored. The code(P0711) just has me concerned about why it was set. I will ohm out the sensor this weekend. I was surprised that the rear O2 sensor was not going off with the bad CAT but it was not set.
thanks
Bill
post #5 of 8 Old 02-02-2013, 05:52 AM
vanzyln
Hello Folks,
I am also battling with a P0711 error on a 2004 Jeep GC 2.7 CRD. I have read the extensive write-ups I believe that it may be a failed sensor or wiring fault. I am now fairly confident that I would be able to test and repair the sensor if required. Before I strip the tranny thought, I want to check the wiring Please can anyone tell me where I can locate the TCM on the vehicle.
Kind regards
Nic
vanzyln is offline
post #6 of 8 Old 02-02-2013, 06:10 AM
ZeeJay1997
Kind regards
Nic
Hi Nic, the TCM is integrated into PCM on >95 Grands. A diagram would make it easier for you. One thing you can do is pull the connector on top of the transmission and check and clean it.
You may get more help if you go over to the WJ forum and start a new post. The post you resurrected an old thread and are now in the ZJ forum.
post #7 of 8 Old 03-04-2014, 05:59 PM
gemsandjewels
P0711 Code
In our jeep the P0711 code was caused by a plugged catalytic converter
gemsandjewels is offline
post #8 of 8 Old 03-05-2014, 05:49 AM
ZeeJay1997
the only way the two could possibly be related is the extra load caused by a plugged convertor caused higher coolant temps. by the time it gets to that point, the engine will barely run. not impossible but highly irregular. what engine do you have?
Where is coolant temperature sensor on 4.7L? Z28Justin WK Grand Cherokee & XK Commander Forum 7 09-29-2009 05:47 PM
Transmission Fluid Temperature Sensor? melswife98 ZJ Grand Cherokee Forum 11 08-07-2009 01:56 PM
where's the temperature sensor on '96? luckyjeep ZJ Grand Cherokee Forum 4 01-17-2008 05:23 PM
Crankshaft position sensor & coolant temperature sensor getting replaced in my 95 GC Keith1975 ZJ Grand Cherokee Forum 3 12-14-2006 03:52 PM
'96 GC Ambient Temperature Sensor wheelytyred ZJ Grand Cherokee Forum 3 11-16-2004 01:12 PM
