P0456 Code, Erased but not gone... - JeepForum.com
post #1 of 5 Old 08-02-2009, 08:03 PM Thread Starter
01Limited45324
My 2001 Grand Cherokee's check engine light came on so I ran a diagnostic and the car returned a P0456 code (small Evap leak).
I checked my gas cap (loose again, might need replaced?) and fixed the probable problem.
I then hooked it up to a handheld Diagnostic and erased the code. However, the light is still illuminated.
My question: If it's not the gas cap, what else could it really be? Does it take a few cycles to get the light to turn off, or does it come off as soon as the problem is fixed?
Yes, I checked wjjeeps.com and did a forum search, but nothing really answered this question specifically.
-Tom
2001 Grand Cherokee Limited
2002 BMW 530i
01Limited45324 is offline
post #2 of 5 Old 08-03-2009, 09:31 AM
Double E
Double E's Avatar
it will take a few cycles to clear as long as
- the code is not triggered again
- another code was also not present at the same time and is still an issue
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #3 of 5 Old 08-03-2009, 12:16 PM
greasefingers
greasefingers's Avatar
1994 ZJ
a) the charcoal canister could be cracked
b) the vacuum line(s) are broken, dry-rotted or have slipped off
c) the gas cap rubber O-ring is shot causing a leak.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #4 of 5 Old 08-03-2009, 01:11 PM Thread Starter
01Limited45324
Here's another twist: If I do the diagnostic cycle (on-off-on-off-on) it still brings up the P0456 code and then it says done after half a second... Normal?
-Tom
2002 BMW 530i
post #5 of 5 Old 08-03-2009, 01:48 PM
Double E
Double E's Avatar
Yes......,
Double E is offline
DTC Code P0456 is intermittent - Is this a serious issue? Saxidani ZJ Grand Cherokee Forum 8 05-30-2015 05:24 PM
Meh: Error code P0456... ptwelve ZJ Grand Cherokee Forum 9 09-30-2009 02:54 PM
P0456 ktplotts ZJ Grand Cherokee Forum 2 11-04-2006 06:57 PM
P0456 - error code .. coudl seomeone do a search . looking for a specific post sanboy ZJ Grand Cherokee Forum 8 10-15-2006 01:04 PM
Codes P0442 & P0456 - Emission Warranty? drmurdoc ZJ Grand Cherokee Forum 1 09-13-2005 10:13 PM
