P0455 Solved - JeepForum.com
post #1 of 8 Old 03-18-2012, 08:07 PM Thread Starter
JasonStebbins
P0455 Solved
For anyone that has the CEL code P0455 (Large fuel vapor leak in the evap system) I fixed mine today since my inspection is up at the end of March. I figured I would post my fix to help out someone else. I've had this problem for several months.
I started with the gas cap since that was the general consensus on here. No dice. Then I replaced the charcoal canister and purge solenoid, still leaking. Then I traced every hose that I could see from the large canister under the bumper cover all the way back to the gas tank. Still could not find a cracked/dry rotted hose
So today I finally broke down and got a smoke test. Turned out to be the steel evap line right above the driver side wheel well. It's down in the crevasse under the hood hinge, where it started to rust through and mud/debris had got in there and the line had snapped right in half. Put six inches of rubber hose on with a couple hose clamps and problem solved. The computer found no faults and inspection was a success.
Hopefully this will help someone in the future
Poop
JasonStebbins is offline
post #2 of 8 Old 03-18-2012, 09:34 PM
Howieb92
Ill have to check that next time I'm in the shop. Because I got that same leak any noticeable difference in power economy or anything after that?
Howieb92 is offline
post #3 of 8 Old 03-19-2012, 06:48 PM Thread Starter
JasonStebbins
Just fixed it yesterday and filled up the tank, I'll let you know if I get a difference in mileage. One thing that went away was the charcoal canister doesn't tick so loud anymore.
Poop
post #4 of 8 Old 03-19-2012, 07:30 PM
Howieb92
Did you have to remove the fender liner to see the line?
Howieb92 is offline
post #5 of 8 Old 03-19-2012, 08:35 PM Thread Starter
JasonStebbins
Nope, it's right behind the brake booster. Down in there above the wheel well.
Poop
post #6 of 8 Old 03-19-2012, 09:24 PM
theblackjack69
Mine happened after I dropped the tank, totally my fault because the O ring was folded under the fuel pump. But for anybody who dropped their tank and got this, re drop and do it all again and you will most likely fix your problem.
theblackjack69 is offline
post #7 of 8 Old 06-25-2013, 05:35 PM
freedom0226
Results ?
so what was the conclusion on mpg after the fix. i am just reading this and i will try to find that line in the am. i am having the same issue.
freedom0226 is offline
post #8 of 8 Old 06-25-2013, 05:44 PM
ZeeJay1997
There's also a rubber splice under the washer fluid reservoir will rot and cause a leak. Changed mine out when I replaced the manifold.
ZeeJay1997 is offline
P0455 ezflip ZJ Grand Cherokee Forum 13 03-09-2010 08:31 AM
p0455 dmolaver15 ZJ Grand Cherokee Forum 8 09-14-2008 12:24 AM
P0455 ABerry ZJ Grand Cherokee Forum 3 08-22-2008 10:30 AM
P0455 CBlakeNS ZJ Grand Cherokee Forum 4 07-26-2008 01:48 PM
p0455 trrogers24 ZJ Grand Cherokee Forum 1 10-16-2006 07:30 AM
