P0340 on 1997 Laredo 5.2L - JeepForum.com
post #1 of 8 Old 02-17-2013, 05:13 PM Thread Starter
eecer
So ive been getting the error code P0340 which I thought just meant replace the crankshaft sensor, did that and the error came back. Looked into the code reading more and I found this:
P0340 - Generic
Type:
-Powertrain - Ignition System or Misfire - ISO/SAE Controlled
Description:
-Camshaft Position Sensor "A" Circuit
-Bank 1 or Single Sensor
P0340 - Chrysler
Type:
Description:
-No Camshaft Synch Signal To PCM Conditions
Cause:
-Engine cranking with 32 CKP sensor pulses received, then the test started and the PCM did not detect any CMP sensor pulses for 2 seconds.
I then looked around and have found three different answers to the camshaft sensor problem, 1. there is no camshaft sensor, 2. the camshaft sensor is in the distributor, 3. the camshaft sensor is built into the ignition plate in the distributor.
Has anyone had this problem before and knows how to fix it? Ive been searching all over and have yet to find anything that says exactly where the sensor is or if theres something else I need to check for this problem. Any help would be great.
eecer is offline
post #2 of 8 Old 02-17-2013, 06:40 PM
dusterdude
The cam sensor is under the distributor cap,its the plate looking thing with wires coming out of it
dusterdude is offline
post #3 of 8 Old 02-17-2013, 08:04 PM
PolkaPower
Here is a pic of it. To replace it you take the cap and rotor off then unplug the sensor and replace. It's really easy. Buy a Mopar sensor don't go cheap.
PolkaPower is online now
post #4 of 8 Old 02-18-2013, 12:35 PM Thread Starter
eecer
Oh so the ignition Plate is the cam sensor too. Lol thats very odd. Thanks for the help!
eecer is offline
post #5 of 8 Old 02-19-2013, 01:44 AM Thread Starter
eecer
The diagram really helps but I cant find a way to remove the rotar. Do I have to remove the distributor to take it out?
eecer is offline
post #6 of 8 Old 02-19-2013, 05:28 AM
Mlarv
2014 JK Wrangler
If your rotor is stuck on the best way I have found to remove it is with a pair of channel locks. I put the open jaw on the plate and use them to wedge the rotor button up you might have to go on either side if it to start it but this normally works for me. When you replace the rotor put a little lube or anti seize on the inside of it.
Good Luck
What Would Scooby Do?
Mlarv is offline
post #7 of 8 Old 02-19-2013, 06:09 AM
PolkaPower
I jst yanked mine straight up and it came flying off. I hit my hand pretty good on the firewall.
post #8 of 8 Old 02-19-2013, 06:11 AM
KoreaZJ
1994 ZJ
Nope. Only 93 to early 94 4.0L need to remove the distributor and shaft to access the camshaft sensor.
KoreaZJ is offline
