P0320 2000 4.7 wj - JeepForum.com
post #1 of 2 Old 07-26-2009, 12:37 PM Thread Starter
Juice_Man
2007 WK
P0320 2000 4.7 wj
i think its a universal code for crank pos sensor circuit but not to sure... i used a little rinky dinky code puller and thats what it told me. wondering if this is a known problem, should i just replace the ckps? or is there something else causing the code, wiring issue or so? it comes and goes, when it trips the light it wont rev past about 3k rpms and gets really really shakey and sometimes cuts off but works fine if i turn the ign off and back on and the light stays on for like 2 days then goes away but dont want to get stranded in the trails
thanks for the info guys
Time is money so i stay late
Juice_Man is offline
post #2 of 2 Old 07-29-2009, 04:14 PM
20jeepwj00
cam and crank sensors are a common issue,usually not a wiring or pcm problem,the sensor is located behind the starter and can somtimes be a little difficult to rmove if its seized into the block.
20jeepwj00 is offline
Infamous WJ P0320 LucasZ ZJ Grand Cherokee Forum 17 10-06-2014 11:05 AM
Code P0320, anyone? Shaunhudgins ZJ Grand Cherokee Forum 3 06-12-2008 09:16 PM
P0320 Cps? AzSun ZJ Grand Cherokee Forum 3 09-22-2006 06:37 PM
Engine stalling-Help with code P0320 RubiCruzer ZJ Grand Cherokee Forum 3 09-19-2006 08:16 PM
