P/S Fluid Questions - MS5931? - JeepForum.com
post #1 of 5 Old 12-07-2009, 08:36 AM Thread Starter
00JGC00
Read this on WJJeeps:
Mopar®P/N 04883077 Hydraulic fluid / Power steering fluid (MS5931)
MS5931 IS THE ONLY FLUID THAT CAN BE USED FOR THE POWER STEERING SYSTEM. NO EXCEPTIONS!
Important note:
The factory fill power steering fluid for all 1999-2004 Grand Cherokees is a unique fluid, MS5931. ATF+4 (MS9602) should not be mixed or used as a “topping off” fluid on the Grand Cherokee WJ. All WJ models should be serviced using ONLY the special MS5931 fluid. ATF+4 is NOT an approved Power Steering Fluid and should never be used under any circumstances. Note that all fluids will darken in color with usage and fluid color is no longer an indication of fluid condition.
I didn't know this when I first got my Jeep and I'm pretty sure I topped it off with ATF+4. Am I screwed? I haven't had any issues at all and it's been about a year and a half. Do you all adhere to this pretty well? Any experience deviating from this? Where is the best place to buy MS5931?
"The" Matt | '00 Limited WJ | "The White Wolf" aka "Willow" aka "Cool Whip" aka "Sweet 'N Low" aka "AKA"
Utah JeepCrew #39 | Club Matt #1
December '11 GCOTM | Build: http://www.jeepforum.com/forum/f197/life-times-979511/
00JGC00 is offline
post #2 of 5 Old 12-02-2012, 11:20 PM
02grandy
02grandy's Avatar
what i think im finding out is the P/N 04883077 in my manual DUH! and from online info its (ms5931).... MS5931 is amber/yellow. the valvoline power steering fluid has the chrysler spec is 5931 - its also a clear amber/yellow color so is that the same as ms5931??? looks like it should be
02grandy is offline
post #3 of 5 Old 12-03-2012, 02:33 AM
Uniblurb
Uniblurb's Avatar
Originally Posted by 00JGC00 View Post
Read this on WJJeeps: I didn't know this when I first got my Jeep and I'm pretty sure I topped it off with ATF+4. Am I screwed? I haven't had any issues at all and it's been about a year and a half. Do you all adhere to this pretty well? Any experience deviating from this? Where is the best place to buy MS5931?
Don't think you're screwed in just topping off the PS fluid with ATF+4 but heard it's hard on seals if your PS unit doesn't call for it. Believe I'd just change it out by disconnecting the return line w/it flowing into a container while adding new fluid to the reservoir.
So are you asking if ZJ owner's adhere to the MS5931 specs and use only Mopar PS fluid? I use any kind of PS fluid designated for Chrysler vehicles, most all of it meets the MS5931 specs, and haven't had any problems. This goes for my 96 ZJ, wife's 2000 TJ, son's 96 XJ and my spare 93 XJ.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
Uniblurb is online now
post #4 of 5 Old 01-05-2016, 05:11 AM
neelis
Does this MS-5931 approval apply to a 2002 Grand Cherokee 2.7CRD with the Mercedes Benz Diesel engine as well?
neelis is offline
post #5 of 5 Old 01-05-2016, 04:23 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
What Uni said isn't a bad idea to do on a regular basis, as it keeps the gear and the pump in better shape. The fluid has a pretty good affinity for moisture and that ain't good for cast and machined parts. Breaking a gear down shows this. Mine had rusty looking gunk all in it.
Originally Posted by HighLonesome
coralman is offline
Where to buy PS Fluid (MS5931) in the UK? saunderela ZJ Grand Cherokee Forum 8 02-02-2010 06:13 AM
Changing Trans Fluid Questions jeep360limited ZJ Grand Cherokee Forum 19 12-05-2009 11:11 AM
fluid questions. mikeprekopa ZJ Grand Cherokee Forum 7 07-10-2009 10:47 PM
D35 fluid questions 01ACRViper ZJ Grand Cherokee Forum 14 12-15-2006 04:48 PM
Fluid questions mikeumkc ZJ Grand Cherokee Forum 8 05-17-2006 10:23 AM
