Oxygen Sensors (more info than you probably want)
| Truck-Lite's New LED Headlamp Series | Ruffstuff Axle Simple Swap Kit! | Spartan Lockers FREE SHIPPING Excellent Prices |
#1 | |
I have been collecting O2 sensor info over the years. Half of the following is in my own words so feel free to correct anything you see wrong.
The O2 sensor is there primarily because of emissions! A second reason is to fine tune fuel management. And thirdly they indicate the state of the catalyst. It was developed to ensure that the correct amount of oxygen is available for a reaction to take place in the CAT which needs O2 to convert other nasty gases to form less nasty gases. (Example carbon monoxide + oxygen = CO2. The sensors upstream (before the Cat) are important for delivering the correct amount of oxygen and for fine tuning the air-to fuel ratio. They help determine the duration of time that the injectors stay open. The oxygen sensor measures the oxygen content from the exhaust stream and from this it can figure out if the fuel mixture is rich or lean The downstream O2 sensors are for measuring the catalyst shelf-life. This will tell if the Cat is spent and needs replacement. This sensor has no effect on the engine performance if it the vehicle is OBDI (up to 1995). A rich mixture consumes most or all of the oxygen so the voltage generated by the O2 sensor will be high (0.6 to 1.0 volts). A leans mixture will have more available O2 left over. In this case the sensor will produce a voltage from 0.1to 0.4v. The perfect average voltage is around 0.45 v for complete combustion. The sensor will only generate an accurate signal when it is at a minimum of 400 C, so it is ignored until the engine control goes into Closed Loop operation (an engine at operating temperature). The O2 sensor also has its own built in heater (2amp load) to get it to temp quickly and so that it is hotter then the exhaust stream. This cuts down the emissions as well. Both O2 sensor measures how much O2 is present in the exhaust stream. The computer does a simple calculation (upstream O2 value – downstream O2 value). Obviously, the upstream valve is always a higher valve. Since a chemical reaction takes place, there is less O2 exiting the Cat. So the math as I see it: If (upstream O2 value – downstream O2 value) = a negative number, than one of the sensors is bad. If (upstream O2 value – downstream O2 value) = 0, then the catalyst is spent and needs to be replaced. If (upstream O2 value – downstream O2 value) = a positive number, then the catalyst is converting oxygen and other constituents to form less toxic gases. Testing the Heater You can easily test the heater circuit with the two white wires. With the engine cold and off unplug the O2 sensor connector. Check for resistance on the sensor side. An Open circuit or mega-ohms means a bad heater circuit. Throw the O2 sensor in the trash. . I measured 4.5 ohms at 45 degrees F outside. This will always store a code. The heater circuit should draw about 2 amps when hot. Testing the measuring circuit The output of the measuring circuit is more difficult. With a hot engine one can back-probe the connector. The voltage output is a Sine-wave. So if you connect a voltmeter across the correct pins (gray & black wires), then the meter will constantly bounce back & forth between 0.1 & 0.9 volts. A good sensor will bounce between a much narrower range like (0.25 to 0.75). The important thing is that the average of the swing equals 0.45 volts. I have not tried to measure this but I think it will be too difficult to measure on a voltmeter unless it has an averaging function. (only the really cool & expensive ones have this) While measuring this circuit, you can pull off a vacuum hose and check to see if the voltage drops (a lean mixture) A bad upstream sensor can cause a decrease in mileage, higher CO and/or HC emission levels Bank 1 sensor 1= the side of the engine which has cylinder number 1 on it and this is upstream of the Cat. This is the driver’s side on Jeeps. Bank 1 sensor 2 = driver’s side downstream sensor or after the Cat. Bank 2 sensor 1 = passenger side upstream sensor Bank 2 sensor 2 = passenger side downstream sensor Harness Connections Heating circuit Orange/with black stripe goes to white wire on sensor (heater 12 volts DC) Black/with light blue stripe goes to the other white wire on sensor (heater ground) Sensing circuit Black with orange stripe goes to the gray wire on sensor (0.1 to 0.9 volts AC signal from sensor) Black with tan stripe goes to black wire on sensor (sensor ground) Many things can cause the sensor to read incorrectly: the built-in heater circuit not working, supplemental gas additives, vacuum leak, and ERG not working can all cause the O2 sensor to appear to be bad. Unfortunately, the best way to determine if the sensors are bad is to have a proper scan performed. That way the outputs are plotted and it can be determined if a sensor is lazy or not functioning properly Many people have reported problems with aftermarket O2 sensors! I would go to your local Dodge or Jeep dealer and give them your VIN number. That way you hand you a sensor that will work correctly with your Jeep; or email Nick at Kolak@aol.com and tell him that you got his name from this forum for a discount.
Cheers Steve Trained Professional Crack-pot Go RU & WVU Football Teams 94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new 03 4Runner V8 (my wife's car) 94 Volvo 850 (my 16-yr old daughter's car) Five cylinder 88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new Last edited by greasefingers; 01-16-2008 at 08:49 PM.. |
#2 |
Excellent information Steve.
Andy '98 Jeep ZJ "Pearl" |
#3 |
Thanks for putting that together…Very informative. What are your thoughts on when to replace them? I have seen a few posts where some people change these sensors as part of their preventive maintenance program in the hopes of maximizing fuel economy. Others wait until they get an engine diagnostic codes letting you know its time to change them.
08 Commander Limited 02 Grand Cherokee Overland-Retired @ 198K 98 Cherokee-Traded @80K "I am buying a new Jeep, just one piece at a time" |
#4 |
Mr. Hyde!
Nicely done Steve
'04 WJ, 6" Clayton LA's, 242 SYE, 35" BFG MT KM2's, 4.56 gears, & D44a locked |
#5 |
Confirmed Street Jeeper
Additional Info Relative to WJs
In order to be more effective in removing harmful emissions, WJs, and I guess later models, use the downstream O2 sensor for additional fine tuning the A/F. Downstream sensors are still used to determine catalytic converter efficiency also. Attached is a description from the WJ FSM (I only attached info for California emissions system, the federal emissions system works the same except for fewer cats and O2 sensors.)
2001 WJ Limited with Quadra-Drive, Kenne Bell Supercharger, 3-inch Kolak exhaust, Stillen rotors (F/R) and MM pads, Addco sway bars (F/R). |
#6 |
I did not realize that. Thanks for additional info
Since the title of the abstract is "Downstream Sensors (California vehicles)" I am guessing that this applies only for California vehicles.
Cheers Steve Trained Professional Crack-pot Go RU & WVU Football Teams 94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new 03 4Runner V8 (my wife's car) 94 Volvo 850 (my 16-yr old daughter's car) Five cylinder 88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new |
#7 |
Vendor
All OBDII Jeeps, that is 1996 and later, utilize the downstream sensor(s) not only to monitor converter health, but also to provide for further fuel trim to ensure converter efficiency. The downstream sensors should thus be replaced at the same intervals as the upstream sensors because a sluggish downstream sensor can mistakenly countermand the input from the upstream sensor.
#8 | |
Hmmmm....
Also, I've heard bad ones can 'soft code' and not give check engine lights. Is it true that an OBDII reader can read this and tell you its bad as well? Reason I ask is that a friend of mine has a small crack in his exhaust manifold but gets really bad gas mileage. I have trouble believing that it's just the manifold and not a bad O2 sensor. |
#9 |
Older ones seem to crap out around 60,000 miles. Newer ones are good for at least 100,000 miles. I would replace it if a code is thrown or if a sudden drop in mileage is observed (calculated by doing the math and not using the overhead display/VIC)
#10 | |
Hmmmm....
What about it being bad and not throwing a code. I seem to remember it happening before. Would a reader at like Autozone pick it up? As for my ZJ, I haven't had any mileage drops and either way, the VIC/overhead is always with in a tenth or two of my calculated mileage. So i'll probably just leave them until I get ambitious and get all my other mods in. |
#11 |
An O2 sensor can drift off of calibration (like any sensor). So it would not show a code if it was going bad (drifting or off calibration). It will throw a code if it is out of some specified range. Fouling can also insulate it (thermally and chemically) That is why a history or plot of the voltages vs time is so important in determining the behavior of the sensor.
A reader at Autozone is useless (unless you have a 1998 Jeep which the ignition key trick does not work) Readers just read the stored codes. The Jeep dealer can actually read more codes than aftermarket readers can do. But a scanner that can plot is the most valuable tool for determining sensors’ characteristics.
#12 |
I have a scanner ( a black box) that connects to my Laptop, for my Toyota 4runner. The 4runner uses a different protocol than Chrysler vehicles, so I can not use it for the Jeep. But I have plotted the four O2 sensors when I bought the new 4runner. Now or anytime in the future I can collect the raw data again. Then I can co-plot the data sets and see if the O2 sensors are bad or drifting from their original brand new state.
#13 |
Hmmmm....
What did that setup run you? Some ridiculous price I assume.
#14 |
$ 150 bucks and well worth it.
#15 |
Sensors are fun (OK maybe the Geek is coming out in me). I have removed some of them from my Jeep and measured certain values. The best example is the CTS (coolant temp sensor). I removed this from the thermostat housing (on 4.0L engines) and submerged it in a pot of water (when my wife was not at home) Then I increased the stovetop burner and paused for equilibrium and recorded the resistance and temperature. I repeated the procedure at different temps.
Now using Excel I co-plotted my data and the data provided from the FSM (factory service manual). BTW the FSM was the best investment I have ever made on my Jeep! Once the curves are plotted an educated evaluation can be determined about the sensors characteristics. Below is an example of collecting data. As see below my original 13 year old CTS (coolant temp sensor) is as good as it was back when it was new [1994] ![]()
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
