Overland WJ front shocks, bottom mounts pressed in? need help ASAP! - JeepForum.com
post #1 of 2 Old 07-09-2009, 07:02 PM Thread Starter
runnerup
hey guys, my friend has a 02 overland WJ and we completed the rear lift already but are having one heck of a time with the front
the shocks and springs are already out but now that we are trying to install the new shocks we have come across the issue of what seems to be the bottom mount bolts being pressed on, we have the physical shock out already, but we need that little metal spanner piece in order to reinstall the new shocks...
does anyone know how to remove the bolts so we can pull the spanner out? thanks in advance!
runnerup is offline
post #2 of 2 Old 07-09-2009, 07:13 PM
ragincanadian4
My lift came with new "bar pins" (the metal spanner you are referring to), but the best way around it would be to get some bar pin eliminators, I recently upgraded to the IRO ones: http://www.ironrockoffroad.com/Merch..._Code=IR-SBPEK
1999 WJ 4.0L 4x4
3" IRO Lift with Bilstein shocks, OEM JK 18's, Addco Sway bar.
ragincanadian4 is offline
Overland wheel size? Need help ASAP PATJ WK Grand Cherokee & XK Commander Forum 4 12-10-2009 01:46 PM
WJ front shock bottom bolt size? mrtosh ZJ Grand Cherokee Forum 2 11-23-2009 04:10 PM
bolts for shocks... need help asap.. GRDCHRKE555 ZJ Grand Cherokee Forum 4 01-18-2007 01:56 PM
02 Overland - Need New Front Differential? KZad ZJ Grand Cherokee Forum 2 10-25-2006 12:00 PM
Softest Shocks for 02 GC Overland geng77 ZJ Grand Cherokee Forum 9 03-17-2006 04:59 PM
