Overheating at idle - JeepForum.com
post #1 of 9 Old 06-01-2009, 08:16 PM Thread Starter
Jeep@02
Overheating at idle
Hi guys, I have a 2002 Grand Cherokee 4.0. While idling the jeep will overheat. As soon as I go down the road the temp. drops to what it should be. While idling the thermostat will open and the antifreeze circulates fine. I have also noticed the fan comes on and turns but doesnít seem to turn as fast as it should. There doesnít seem to be much are moving. It's hard to tell though. Any ideas? It sounds like a fan clutch. But I believe this has an electric fan.
Jeep@02 is offline
post #2 of 9 Old 06-01-2009, 08:25 PM
00RedWJ
2006 WK
I had the same problem and it was a bad fan motor. It would spin but barely enough to move any air and the car would overheat at standstill. Replaced the fan motor and it cranked much harder - no more overeheating. My 2000 has an electric fan but I believe your 2002 has a fan clutch. I suspect the fan clutch could be bad. they're not that expensive on am-autoparts.com
2000 Red Laredo WJ
4.0 with Selec-trac - Sold
2006 Black Laredo WK
3.7 with 95,000 Miles
00RedWJ is offline
post #3 of 9 Old 06-01-2009, 09:44 PM
jtsjeep99
MY 99 has an auxiliary electric fan and my fan relay went out a couple of years ago. I first tested the fan by jumping the wires in the plug to the battery and found the fan to be good and the fan wasn't running when hot so the relay was the problem. The replacement took 15 min and the relay is under the passenger headlight. Do a search on the fan relay replacement on the site and you should find the write-up.
jtsjeep99 is offline
post #4 of 9 Old 06-01-2009, 09:51 PM
xJoshxx
2012 WK
do you have a tow package?
tow packages have both E-fan and Fan clutch
i suspect Fanclutch it isnt workin right it's basically it's spinning at a slower sping than the motor.
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #5 of 9 Old 06-02-2009, 04:28 AM Thread Starter
Jeep@02
No I don't have the tow package and I actually replaced the fan relay a while ago. Advance auto parts told me I have a fan clutch in my 2002. I guess I donít understand how you could have both electric and a clutch? The clutch was about 50 bucks. Hopefully it is something cheap and easy.
Jeep@02 is offline
post #6 of 9 Old 06-02-2009, 07:36 AM
xJoshxx
2012 WK
tow packages had both the E fan sits behind the radiator in front of the fan shroud. then the Fan clutch is attached to the Water pump
2011 WK2 ORA2 sold
xJoshxx is offline
post #7 of 9 Old 06-02-2009, 08:25 AM
4jeepers
Had the same problem 2 weeks ago! Turned out to be the cooling fan relay! To check, disconnect the plug to the fan and take jumper wires and jump fom the batt + terminal to the fan side plug (female) and the other to a good ground. Jump the two pin contacts in the plug the purple stripe wire should be the positive and the green the negative. you may have to reverse the positive to the pins (try both ways) If the fan runs strong then it is the relay and you have no way to check it. The relay is cheap around 35.00. The bad thing is that it is a Bi#^h to get to. It is under the headlight between the Plastic tray and metal frame panel. I just cut the plastic tray rather then removing the bumper cover and who knows what else! Good Luck!
4jeepers is offline
post #8 of 9 Old 06-02-2009, 09:12 AM
terryj
2015 WK
If you have the fan connected to the water pump then you'll have a clutch fan, if you have no fan connected to the water pump then it an electric fan mounted in the radiator shroud. If you have A/C the cooling fan relay is also used to operate the A/C clutch, if your A/C clutch engages and then disengages, after a few seconds, then its your relay that is causing the problems.
terryj is offline
post #9 of 9 Old 06-02-2009, 09:54 AM
00RedWJ
2006 WK
Electric fans were gone after 2000
2000 Red Laredo WJ
00RedWJ is offline
Overheating at idle.. KevinM90 ZJ Grand Cherokee Forum 2 08-02-2009 02:40 PM
Overheating in idle-Radiator fan doesnt start donniejamesrio ZJ Grand Cherokee Forum 3 07-14-2009 09:38 AM
Overheating while stop/idle shoaba ZJ Grand Cherokee Forum 6 12-29-2008 11:00 PM
Overheating at idle jimperry ZJ Grand Cherokee Forum 2 08-27-2007 12:34 AM
2000 still overheating at idle... adamclinch WJ Grand Cherokee Forum 2 06-17-2004 04:39 PM
