Quantcast Overheating help... - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Overheating help...
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 11-15-2008, 03:44 PM   #16
SplitPoly
2003 WJ
Originally Posted by Windowsrookie View Post
3. Something could be clogged up either in the engine or radiator. (Not likely to just happen randomly though).
Like if the water pump came apart and distributed itself throughout the engine?
Or just a general buildup of crap in there?
- Rick
SplitPoly is offline   Reply With Quote
Old 11-15-2008, 03:47 PM   #17
Windowsrookie
- Rick
Either could be possible, but if it was the water pump you would definitely hear/see something wrong with it.
Just check your relay first, it fails on every 4.0 WJ at some point.
2000 Grand Cherokee Laredo 4.7L V8 Quadra-Drive
1987 Wrangler 4.2L
Windowsrookie is offline   Reply With Quote
Old 11-15-2008, 07:01 PM   #18
SplitPoly
2003 WJ
Just a "what if" question:
If my water pump did come apart, I don't want to run the engine, right? Wouldn't it send bits all through my coolant system?
- Rick
Old 11-15-2008, 09:01 PM   #19
Windowsrookie
It's already happened if that's so. But that didn't happen because your water pump would have been making awful noises. I'm 99% sure it's your Fan relay.
1987 Wrangler 4.2L
Old 11-16-2008, 02:56 PM   #20
elmer_fud
- Rick
if your water pump came apart you would not have any circulation, and your engine would keep heating up until it stalled. I still think it is your fan
Brian
95 ZJ, 5.2 V8,160,000 miles
Colorado Jeep Club member Pi
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline   Reply With Quote
Old 11-25-2008, 12:05 AM   #21
SplitPoly
2003 WJ
Well... it was the relay. I can't thank you enough for advising me towards it. Saved me some time and money.
Here is what I did to fix the problem.
Removed grill, fascia, and headlight*****. Someone else had already cut a hole in the plastic...
I cut the relay harness and made my own harness extension.
I soldered ends onto the original harness, connected, and insulated.
New bracket with new relay:
Installed:
I was a little afraid of vibrations, so I zip-tied the bracket to the battery handle.
Fired up the Jeep, no codes, no lights, no dings...
Test drive was flawless, fan functioned perfectly, temp fluctuated between 195 and 205.
Thanks again for the help.
- Rick
*****Edit: You don't have to remove the fascia and grill, just the headlight. I took mine off because I was also installing tow hooks.*****
Glock Forum
