Overheat issues? Blown head gasket? - JeepForum.com
post #1 of 8 Old 02-23-2013, 02:03 PM Thread Starter
Scottie350
Ok I've been reading and reading and can't come to a definitive conclusion. It's the 5.9
When the truck gets hot and I shut it off. It starts bubbling coolant into the reservoir, but doesn't really seem to if I shut it off at normal temps
It only seems to start to overheat if its sitting idleing. (It is t very warm out yet. Was -6 the other day )
My oil doesn't look bubbly or milky as I've read it should if it's head gasket
I've replaced the rad cap, the truck DOES seem to go through coolant, and if it heats up and I shut I off and start it while it's warmer white smoke comes out just at start up. Otherwise it doesn't seem to
Scottie350 is offline
post #2 of 8 Old 02-23-2013, 02:06 PM Thread Starter
Scottie350
With rad cap off the coolant will slightly rise out of the cap bvery slowly but no actual bubbling out of it happens, , It does still seem to have balls. And no real power loss from when I got it is noticed, So. Can u rule out head gaskets? Would plenum cause this?
Or do u think likely the rad ? It LOOKS original
post #3 of 8 Old 02-23-2013, 02:08 PM
FAlfani81
Sounds like bad head gasket or a warped or cracked head. It could be dumping into the cylinder. This is what my WJ is doing. I'm just burping it once a week till I feel like actually fixing it.
FAlfani81 is offline
post #4 of 8 Old 02-23-2013, 02:15 PM Thread Starter
Scottie350
Ya see was worried of this. But same I'm doing, I refuse to fix it right now, I'm buying a brand new car and will keep this maybe for a project build , it has nearly 400xxx on it so a new engine or rebuild is due, if I keep it n do that I think ill stroke it
post #5 of 8 Old 02-23-2013, 02:18 PM Thread Starter
Scottie350
Just don't wanna give it up as I ordered Kolak and thorleys a year n a half ago. Just got em in and installed like 4 months ago ( since I had em and this has been my winter beater). So I don't really wanna scrap er
post #6 of 8 Old 02-23-2013, 02:38 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
head gaskets are easy as pie to do. but it might not be the problem.
is the fan working?
ratmonkey is offline
post #7 of 8 Old 02-23-2013, 03:19 PM Thread Starter
Scottie350
Pretty sure rat, it sounds like it is, but I haven't physically checked, ill get back to you on that , but I was thinking that may be it also , also once I get up to the camp at work I'm gonna drain the coolant and replace , but seems to chew up coolant, and I don't see it coming out anywhere
post #8 of 8 Old 02-23-2013, 04:09 PM Thread Starter
Scottie350
It's the fan guys, just checked. It sounds like its turning but physically isn't, fan must've fried, Well that's a relief
