Overhead console....again - JeepForum.com
post #1 of 5 Old 05-25-2005, 03:54 PM Thread Starter
rschunk
rschunk's Avatar
Ok, I'm still having problems with the temp readout on the overhead console on my 93 GCL 4.0. It has been indicating -40 and then shifting over to OC.
I finally got the service manual today (30 days after ordering) and got to searching it and found a trouble shooting procedure for the console.
I have already replace the sensor itself (it was only $17.50..way better than I expected)
End result is the display shows CCD and the manual indicates to replace the ccd.
So where is it and how much does it cost?
"Mean Green"
4.0 inline 6
3" BDS Suspension lift
ARB bumper with
T-Max 9000# Winch
Optima Yellow
JKS Swaybar Quick Disconnects
30x9 Dunlop Mud Rovers
Rocky Road Rockrails (Great rails, lousy shipping)
GPS Street Pilot
175,000 miles & still going!
93 Green GCL
Green Jeep Club Member #163
check out the pictures..
Also a 'Graphite' 2002 Grand Cherokee Laredo. Graphite Jeep Club Member #1
rschunk is offline
post #2 of 5 Old 05-25-2005, 04:08 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
The CCD is the bus (wiring) between the PCM and the module in the console.
Edit:
If you have ATC, then the temp sensor connects to the ATC controller, and the controller connects to the compass/trip module in the overhead console. If you don't have ATC, the temp sensor connects directly to the compass/trip module.
HighLonesome is online now
post #3 of 5 Old 05-25-2005, 05:17 PM Thread Starter
rschunk
rschunk's Avatar
Ah, I take it by ATC you mean Automatic Temperature Control
No, don't have that. I'll have another go at trying to figure out the wiring diagrams,
since the OC indicates open circuit. One of the other forum members suggested using a low value <20K resistor to short across the leads to find the open.
I suppose I could just short the ccd terminals in the connector at the overhead. I did manage to figure out that connector!
Man, I hate to crawl around under the dashboard. They should make auto designers do three years as a shadetree mechanic before they ever let them get near a CAD terminal
"Mean Green"
4.0 inline 6
ARB bumper with
T-Max 9000# Winch
Optima Yellow
GPS Street Pilot
93 Green GCL
rschunk is offline
post #4 of 5 Old 05-26-2005, 08:13 AM
HighLonesome
Yes on the ATC. You are lucky...I have it and hate it. I have a similar problem and I am curious as to what you will find. Sounds like you already know your stuff, but make sure you disco the battery before shorting out the CCD bus.
I was going to look at the diagnostic procedure in the FSM last nite, but forgot. I was wondering what procedures or checks led up to the OC on the CCD bus. ?
post #5 of 5 Old 05-26-2005, 10:22 AM Thread Starter
rschunk
rschunk's Avatar
Overhead Console....again
I have the ATC in my 97 Grand. I like it, but then it hasn't given me any problems. Only thing with that one is the ABS light is on, and the shop says 600.00 for fixing it..
Ok, lets see....I sent the unit out to get the A/C fixed and a replacement instrument bezel put in because the speedo was toast. When it came back I noticed the outside temp was showing 'OC'. When you turn on the key, it shows -40 degrees and then quickly shifts over to 'OC'. Someone else on the list said it meant Open Circuit. I thought it was stuck on Zero Centigrade
First thing I did was buy a replacement sensor ($17.50). Of course I couldn't get my hand up between the grill and rad to get it out, so I resorted to sawing off the mounting tab. I replaced the sensor and remounted it down lower than original but in the same vertical. No joy in Jeep land..same thing.
The same person mentioned putting a <20K ohm resistor across the connectors going back to the console. This seemed like a great idea, until I tried to follow the wiring. So I resorted to waiting for the FSM that I ordered a month ago. That is another story in itself.
So last night I got into the FSM and found the self diagnostic test (page 8C-7). Ran the test and it showed 'CCd' as the code, which indicates "the module is not receiving all the CCd messages required for operation." So I guess Open Circuit is still viable. The harness connector, same page, Fig. 3 shows pins2/3 as the CCD feed. Looking through the 113 wiring diagrams which have PLENTY of CCD lines, I found diagram 74 which shows the Oustide Ambient Temp sensor for a non-ATC unit. That leads me back to a connector <D41> which is under the dash.
So basically I'm looking at pulling the dash.
Sorry for the long narrative, but you asked...
"Mean Green"
4.0 inline 6
ARB bumper with
T-Max 9000# Winch
Optima Yellow
GPS Street Pilot
93 Green GCL
rschunk is offline
Overhead console spievy79 ZJ Grand Cherokee Forum 5 02-20-2009 04:00 PM
overhead console coonash ZJ Grand Cherokee Forum 8 11-20-2007 02:22 PM
94 GC Lar. overhead console NYR99 ZJ Grand Cherokee Forum 4 10-15-2004 12:26 PM
putting an overhead console in a non-overhead consoled gc gregmondro ZJ Grand Cherokee Forum 0 08-04-2004 02:31 PM
Overhead Console MaineZJ ZJ Grand Cherokee Forum 3 06-04-2003 07:06 PM
