overdrive solenoid/tcc solenoid same thing? - JeepForum.com
post #1 of 31 Old 02-15-2009, 02:44 PM Thread Starter
SoCalDevyn
hey guys, sorry to make another thread but i really need a quick answer so thought this would help.
well my previous post talks about the jeep stalling when i got into reverse when the motor is cold, reverse works fine once i drive around a bit. and when i get to 50mph i get this hard jerk thing like the converter is locking up or something. well i was going to replace the tcc solenoid and the dealer only had something called the overdrive solenoid so i got that but i wanna make sure the two are basically the same thing and it will fix my problem. trying to get this done today.
thanks guys,
devyn
98 ZJ Limited 5.2, Blacked Out, 6.5" IRO Long Arm, 15x8 Pro Comp 97's, 35" MTZ's, Custom Front Bumper, Rusty's Disco's, KOR Light Bar, 8000K HID's, Magnaflow, CB, 5% Tint, System, TJ Gas Bezel, JKS Rear Trac Bar, Rusty's Front Trac Bar, KOR Stabilizer, Cold Air Intake, E-Fan, RCX Diff Guard, Clayton Brake Lines, MSD Ignition, Gen Right Louvers, Custom Sliders, IRO Belly Skid, Rigid Lights
SoCalDevyn is offline
post #2 of 31 Old 02-15-2009, 02:45 PM Thread Starter
SoCalDevyn
also their computers at the dealer only showed two solenoids in the tranny. govorner solenoid and the OD solenoid wich i got
post #3 of 31 Old 02-15-2009, 03:54 PM Thread Starter
SoCalDevyn
anyone?
post #4 of 31 Old 02-15-2009, 08:43 PM
Mikeyb928
good luck around here.... i've been trying to find out real tech info for a week and haven't gotten the answers i'm looking for.... but i am actually trying to pull my valve body right now and i know from the little bit of info i've been able to find else where that the overdrive and lockup solenoid are connected on the same bracket with a wiring harness. I'm looking for the temp sensor which from what I've read it is connected to these solenoids but am having difficulties getting the linkage to come apart, Hope this helps
Here's what I'm talking about with the overdrive/lockup solenoids
http://cgi.ebay.com/ebaymotors/_Car-...3A1|240%3A1318
-Teraflex 4" Springs, Doetsch Tech 8000 Shocks
-IRO Track Bar, IRO Sway Bar Extensions
-Painted Cladding and Bumpers, De-ambered Headlights
-265/75/R16 Maxxis Bighorns on 16"x7" Cragar Soft 8's
Mikeyb928 is offline
post #5 of 31 Old 02-15-2009, 08:55 PM
ZeeJay1997
On the 42RE, the temp thermistor is part of the gov pressure sensor.
OD and TCC are sold as an assembly and the valve body has to come off to replace it.
http://www.transmissionpartsusa.com/...id_s/10538.htm
ZeeJay1997 is offline
post #6 of 31 Old 02-15-2009, 09:01 PM
3_high_low
I think TCC lock up should only happen when you're cruising in OD and it should be barely noticeable.
Is the vehicle already in OD when it jerks, or does the jerk happen when it shifts to OD?
To answer your question, no, I don't think the OD solenoid and the TCC solenoid are the same thing.
EDIT: I see you got some better answers while I was typing lol.
3_high_low is offline
post #7 of 31 Old 02-15-2009, 09:04 PM
ZeeJay1997
It locks up in 3rd too if the OD is disabled.
post #8 of 31 Old 02-16-2009, 11:15 AM Thread Starter
SoCalDevyn
hmm thanks for the post, thats actually the same part i got at the dealer. is that what controls the converter locking or jus when OD shifts?
but yea ive noticed its hard to get help with there kinda questions.
3_high_low: it will jerk right after switching to OD but if i am hard on the gas sometimes it will not do it
ZeeJay1997: ill have to try that, turning OD off and seeing if it still does the jerk. if it does then what do u think should b replaced?
edit: on was on this website and found this http://www.transmissionpartsusa.com/...-00053392c.htm
same part i got but there says it the OD/lock-up solenoid so maybe a posibility is controls both?
ive also been reading around trying to find stuff and i cant find any TCC Solenoid info for the 44RE tranny so maybe the two are the same part?
post #9 of 31 Old 02-16-2009, 04:53 PM Thread Starter
SoCalDevyn
anyone......
post #10 of 31 Old 02-16-2009, 05:40 PM
ZeeJay1997
Devyn, The part in the linked pic is the OD TCC solenoid assembly. Why do you think this will fix your problem?
Im pretty sure this has nothing to do with reverse. Your revserse problem sounds like low fluid.
The other problem could be any number of things, depending on which shift it is occurring on.
Do the simple stuff first, fluid level, cable adjustment.
If your going to throw parts at it, go ahead and change all the electronics in the tranny. You can get them on the site I linked for around 200 bucks.
EDIT BTW, I my experience is with a 42 RE, so I don;t know the difference.
post #11 of 31 Old 02-16-2009, 05:52 PM Thread Starter
SoCalDevyn
well i was told that part would fix it, atleast the OD shift jerk thing going on.
the reverse thing is what gets me cause it works fine once i drive a bit. and the cable is already adjusted(TV) and the fluid is new along with the filter, changed two weeks ago. and i dont have money to spend so im trying to get only what i need to get it fixed.
and as far as i know the 42RE and 44RE have parts that are the same
post #12 of 31 Old 02-16-2009, 05:57 PM
ZeeJay1997
Are you checking fluid while hot, level, idling, in neutral, and shift through all positions before checking?
If your set on replacing the OD solenoid, put some Lucas in it when you top it off and see if the reverse prob goes away.
post #13 of 31 Old 02-16-2009, 06:35 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
no on the lucas, and if you'd check the fsm you'd know that stalling or lurching when put in reverse is a possible symptom of the tcc solenoid being bad, combine that with the hard lock up in 4th and there you go.
ratmonkey is offline
post #14 of 31 Old 02-16-2009, 07:08 PM
ZeeJay1997
I got lazy and didn't look at the FSM. Also didnt ask how old the tranny is b4 I recommended Lucas... fallin back on the free advice...
post #15 of 31 Old 02-16-2009, 07:20 PM Thread Starter
SoCalDevyn
yes that is how i check the fluid.
and i will b if that is what the problem seems to b?
thought about actaully putting some lucas in it.
why no on the lucas?
whats the fsm? Factory Service Manual? Cause all i have it the Haynes book
and are u saying then it is the OD/lock-up solenoid? cause from my research i can find no tcc for the 44re and its jus one part that is the OD and converter lock up solenoid which i aready got from the dealer
4x4 Solenoid? BonesWK WK Grand Cherokee & XK Commander Forum 3 04-17-2009 09:44 AM
WJ Cooling fan solenoid finrisk ZJ Grand Cherokee Forum 0 10-26-2007 01:38 AM
42RE solenoid going out? 02Lightning ZJ Grand Cherokee Forum 2 12-30-2005 10:46 AM
Tranny/Overdrive issue - TPS? Solenoid? Help! ShadMan ZJ Grand Cherokee Forum 9 08-29-2005 07:40 PM
Converter or solenoid... MoneypitGC ZJ Grand Cherokee Forum 1 06-01-2004 12:48 AM
