Overdrive QUE?!?!?! - JeepForum.com
post #1 of 7 Old 05-31-2003, 05:46 PM Thread Starter
spichman510
spichman510's Avatar
Overdrive QUE?!?!?!
Ok, i am starting to actually get some knowledge about jeeps here, but heres a normal car question. What exactly does overdrive do? And was it causing my trans to shift up then down real fast and jerk so much that i lose power when i am accelorating pretty fast? I turned OD off but i havent floored it yet to see if its the same, will do that tongiht.
Spicher
-'98 5.9 Grand Cherokee-
spichman510 is offline
post #2 of 7 Old 05-31-2003, 07:50 PM
Ryan2son
OD decreases your RPMs ~500 and gives you better gas mileage. I turn mine off in the mountains because the tranny will shift, shift shift (did I mention shift - hehehe).
Richard
1999 Jeep Grand Cherokee Laredo
4x4, 4.7 V8, Quadratrac II, Loaded
A Hail the Mighty Philadelphia Eagles!
Ryan2son is offline
post #3 of 7 Old 06-01-2003, 12:43 AM
Zaphod
SACPOWERTV.com
Zaphod's Avatar
1981 J-Series Truck
I believe overdrive allows you to engage and disengage the highest gear. so when overdrive is on in a 4-speed AT, you have all 4 gears. when it is off, you have only the first 3.
the reason your jeep was shifting up and down rapidly with overdrive on is that the car is at an angle on the hill that your present speed and engine RPM kept the computer right on the line of when to up/down-shift. it couldn't decide which to do, so it did both, over and over. turning off overdrive disables that fourth gear, keeping the jeep in the 3rd gear and smoothly rolling up the mountain with less abuse to your tranny.
correct me if i'm wrong, y'all. i hate spreading mis-information.
Oh, and for spichman:
Don't think overdrive would do that with your tranny, especially if it is on level ground. That sounds like a different (and very nasty) tranny problem.
Ryan
81 J20 8400#
"The existence of flamethrowers is proof that someone,
somewhere, said to himself, "I want to set those people
over there on fire, but I don't feel like walking over there to do it."
Zaphod is offline
post #4 of 7 Old 06-01-2003, 09:49 AM Thread Starter
spichman510
mmmmmmmmm, i like very nasty tranny problems,...alot. Ill take it in and check it out, thanks for all the info.
Spicher
post #5 of 7 Old 06-02-2003, 06:46 PM
Stocker
Ryan2son & Sonar have it right...
OD is simply your highest gear, by definition higher than a 1:1 direct ratio. Fourth in a 4 speed, fifth in a 5 speed etc. The OD lockout just, well, locks out the highest gear. If conditions cause your tranny to constantly hunt in & out of OD, lock it out - it's less stressful to the tranny & driveline. If you floor the throttle, the tranny should shift down - out of OD.
1995 5.2 ZJ Sold... but still in the family
Stocker
Stocker is offline
post #6 of 7 Old 06-02-2003, 10:21 PM
ZR7 Ken
ZR7 Ken's Avatar
Spicher,
When you take your ZJ in for service, have them check for a service bulletin about "bucking at wide-open-throttle". There were some governor pressure sensors that would allow the vehicle to hit the rev limiter before upshifting. Rev limiter causes jerking/bucking due to fuel shutoff. Sound like your problem??
ZR7 Ken is offline
post #7 of 7 Old 06-02-2003, 10:35 PM Thread Starter
spichman510
ken,
that sounds EXACLTY like my problem. Thats prob what it is, if not ill be one unhappy camper. thank you for that one.
Spicher
4.0 Overdrive befumo ZJ Grand Cherokee Forum 3 10-17-2009 04:05 PM
Overdrive or no overdrive? luckyjeep ZJ Grand Cherokee Forum 6 10-26-2007 07:27 PM
to overdrive or not to overdrive UltimatE ZJ Grand Cherokee Forum 5 07-25-2007 08:23 AM
Overdrive S.O.B Bloodbath ZJ Grand Cherokee Forum 15 05-15-2006 05:24 PM
94 GC going into overdrive on its own!! tinker1121 ZJ Grand Cherokee Forum 11 06-19-2005 05:12 PM
