Overdrive problem...Code 23 - JeepForum.com
post #1 of 1 Old 10-01-2009, 06:17 PM Thread Starter
CaseyC
1994 ZJ
Drove my 94 ZJ 4.0 to the grocery store. When I came back out noticed a puddle of water under the engine, on the manifold side. Did a quick inspection and found that one of the freeze plugs had corrosion and was leaking. I hadn't lost much coolant, so I drove it home. On the way, it stopped going into overdrive. I haven't driven it since then, but today I went out and pulled the O/D codes and came up with a 23 "Converter clutch solenoid output". Is it possible that the water shorted out the solenoid connector on the side of the tranny?
Thanks,
CaseyC is offline
overdrive problem in my 93 zj ManikJeepZJ ZJ Grand Cherokee Forum 8 12-19-2008 12:15 AM
Overdrive problem _H2_ ZJ Grand Cherokee Forum 2 01-19-2008 08:25 AM
42RE overdrive problem 98 GC 4.0L stufor ZJ Grand Cherokee Forum 6 09-14-2006 04:11 PM
1995 GCL overdrive problem Mustang5ohhh ZJ Grand Cherokee Forum 1 09-15-2005 07:41 AM
HELP! SOS! 94 GC overdrive problem-Will VSS solve problem tinker1121 ZJ Grand Cherokee Forum 1 07-15-2005 10:08 AM
