overdrive goes out - JeepForum.com
post #1 of 11 Old 08-25-2013, 09:44 AM Thread Starter
bigfoot493
overdrive goes out
so i've searched and could not find an answer to my question to save my life. I have a 93 zj w/4.0 auto. when it rains or i cross a mud puddle or standing water the od kicks out and the light flashes and then stays on. like if im ridding down the highway doing 65 and it starts poring it will kick out and the light flashe and comes on and i can push it all day long and the od will still stay off. but as soon as i hit dry pavement od comes back. so the mud puddle or standing water aint to bad bc when im through it the od works but it sure does suck ridding down the highway in a rain storm. any ideas where i can start?
also i found this out one day going down the highway and was getting off onto another road on the ramp and it just started pouring and when im 1/2 way in the curve the od kicked out ant the tranny downshifted and the rear end got squirley...............not to fun. but now i know what to expect when it rains. so im ready for it.
1994 5.2 jeep grand cherokee laredo
1993 4.0 jeep grand cherokee laredo
bigfoot493 is offline
post #2 of 11 Old 08-25-2013, 10:02 AM Thread Starter
bigfoot493
also checked the factory service manual i have and did not see any thing in there about od going in and out only about it either staying in od or not going out.
post #3 of 11 Old 08-25-2013, 10:26 AM
Syncityj
I read my owners manual and it says when the transmission overheats the OD will kick off.
Syncityj is offline
post #4 of 11 Old 08-25-2013, 10:59 AM Thread Starter
bigfoot493
it only does it when it rains thogh. like i can be driving normal all day and it sprinkels and get the road wet and it will kick out but as soon as i reach dry pavment it will be back working fine...............is there some kind of electrical conector for the od or on the od
post #5 of 11 Old 08-25-2013, 11:14 AM
ZeeJay1997
the TCM monitors the thermistor in the gov pressure sensor to determine trans temp. this resistance value is around 1000 ohms (to ground) when cold. as the transmission heats up, this resistance value decreases.
water is a conductor. when the wiring gets wet, it lowers the resistance to ground on the trans temp circuit, fooling it into an overtemp condition.
my first step would be to follow the wire harness from connector on the top of the transmission and check for damage. if nothing obvious, disconnect harness from transmission, clean connectors, use dielectric grease, reassemble.
ZeeJay1997 is offline
post #6 of 11 Old 08-25-2013, 12:19 PM Thread Starter
bigfoot493
thanks. ill give that a try and try to find some water to drive through or just wait till it rains again.
post #7 of 11 Old 08-25-2013, 12:41 PM
Scopez
1994 ZJ
Got a water hose? Spray your road down and drive over it haha.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #8 of 11 Old 08-25-2013, 12:47 PM
Syncityj
I was thinking why not just hose down the part or connection in question then go for a drive.
Syncityj is offline
post #9 of 11 Old 08-25-2013, 12:56 PM
Scopez
1994 ZJ
Spray bottle with water! Hahahah.
Scopez is offline
post #10 of 11 Old 08-25-2013, 01:09 PM Thread Starter
bigfoot493
yea knowing my luck that would mess somthing else up. I just changed my front passenger side axle shaft and yesterday while driving on the beach heard a new clunkig noise from th drivers side that wasent there before. NEVER ending story with this jeep. Before i got this jeep 2 yars ago it had sat for 3 years and was not driven. now alot of problems are starting to surface. coolant sensor, brake callipers, radiatior, starter,......... more to come
post #11 of 11 Old 08-25-2013, 02:00 PM
ZeeJay1997
be sure give the harness a detailed inspection with plenty of light and an inspection mirror if necessary. there was a thread last week where the same harness was causing a tranny problem. it happens.
