Over-Heating - Page 2 - JeepForum.com
post #16 of 24 Old 11-03-2009, 04:31 AM
colt808
Originally Posted by selim View Post
Ok guys. You are all going to hate me now due to my new discovery.
Today when the car cooled down enough I opened the radiator cap to see that Water was not visible. But, the coolant level was half way so from that I assumed that the water in the radiator would be fine.
Anyways, I filled the radiator up and it took about 1.5litres of water.
After that, I ran the car with the cap off for a little bit and the water love seemed to be going down and coming back up. From this I am assuming that water is flowing fine through the radiator and engine.
Also, I took the switch off the thermostat and put it back on... Thinking the connection may not have been sitting on properly.
So, I drove the car as per normal... With the a/c cranked up and the car did not over heat at all.
So that's tht problem.
Now my next concern is that why does the water in the radiator go low, and collant box stays fine. It use to be the other way around!
What could be the cause for the radiator to get low?
Thanks guys and yes I know... I'm a d#%k h*+d.
Selim
When you say water, I hope you mean coolant. If not, you need to know that water tends to boil off and can be the cause of your empty radiator. Not to mention, the mineral deposits that can really screw up the cooling system.
Your overflow tank level would be more important if you had a closed system (no radiator cap). But since you don't have a closed system, you need to always check both. I think that you probably let the coolant level in the radiator drop to low and it was unable to create a vacuum to siphon coolant from the overflow tank. Since you let the system drop so low, you really should purge any air from the system. If you're not sure how, just check the levels for the next couple of days and top off as necessary. This should take care of it.
So keep the radiator and overflow at the correct levels, you should have no problems. And if you're using water...I strongly recommend you do a complete flush and refill with the proper coolant mix.
colt808 is offline
post #17 of 24 Old 11-03-2009, 05:36 AM Thread Starter
selim
Mate, your a legend. I will do exactly that and fingers crossed it will work.
Ill post back to give you an update.
Cheers mate
selim is offline
post #18 of 24 Old 11-03-2009, 05:51 AM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
A new radiator cap might help also.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #19 of 24 Old 11-03-2009, 06:00 AM Thread Starter
selim
I have changed that not long ago thinking that may of been the original problem... but it hadnt made a difference at all.
selim is offline
post #20 of 24 Old 11-03-2009, 11:37 AM
gunner454
The way i have used to make sure my radiator and everything was full was park it on a hill, facing upwards. When the engine is cool, remove the radiator cap and top off the coolant. Then, with the cap still off, start the engine and turn the heater on full blast hot and just let it run, as coolant begins to circulate the level drops a bit and just keep adding more till its full. Obviously don't let it run for a long long time. Once that is done, put the cap back on and you should be golden. Has worked for me.
gunner454 is offline
post #21 of 24 Old 11-03-2009, 07:17 PM Thread Starter
selim
Excellent... will do that now.
But there has to be a leak somewhere. Any ideas on how I can find that leak???
selim is offline
post #22 of 24 Old 11-03-2009, 09:41 PM
colt808
I did not even think to suggest that...the last time I did that was back in high school shop class. But we did it was with the engine warm so the t-stat is open. I guess starting out cool would be safer and still get the same results. You can also "burp" the upper hose by squeezing it a few times.
colt808 is offline
post #23 of 24 Old 11-05-2009, 07:20 AM
michiganmaveric
Got Beer?
2011 JK Wrangler
If there are no visible signs of a leak I would start with a compression check to see if you have a bad head gasket.
Lifetime member #13
post #24 of 24 Old 11-05-2009, 11:04 AM
gunner454
x2
Also a flexible mirror has helped me in finding small leaks in the past as well.
WJ Heating went off Mollerdrengen ZJ Grand Cherokee Forum 14 01-09-2007 11:18 AM
Seat heating does not work, but heating elements are ok WolfgangK ZJ Grand Cherokee Forum 12 04-17-2006 10:44 AM
Is my ZJ over heating? Eds97ZJ ZJ Grand Cherokee Forum 9 06-09-2005 06:30 AM
Ov heating spichman510 ZJ Grand Cherokee Forum 13 11-06-2003 09:47 PM
over heating g0Nzo ZJ Grand Cherokee Forum 1 04-15-2003 02:20 AM
