Over-Heating - JeepForum.com
post #1 of 24 Old 10-20-2009, 11:01 PM Thread Starter
selim
Over-Heating
Hi,
I have a Australian (right hand drive) 2001 Grand Cherokee Laredo and the car seems to overheat when it comes to a hold.
Once the car starts moving again, the temp goes to half way or a little over.
This has been happening for the past 1 month and not sure what its from.
The other day it happened again, and I turned the air-con off and then on again, then the temp gauge did not go over half way which seemed like its gone back to normal.
I have checked the fan and everything seems fine to my knowledge.
Just a little history on the car... I have been topping up the coolant every 3-4weeks due to being farely low and the warning coming up in the car.
It seems that now with the overheating problem, the coolant has not needed to be filled!!! Seems wierd that one problem has been solved and another has started.
Can anybody shed some light on this!
Its really anoying me and am on the erge of selling it!
Thanks
Selim
selim is offline
post #2 of 24 Old 11-02-2009, 02:50 AM Thread Starter
selim
hi again,
Please can anybody help with me with this overheating issue.
It seems to be getting worse... especially when I stop at traffice lights.
Sometimes Im scare to even stop.
Thanks
Selim
selim is offline
post #3 of 24 Old 11-02-2009, 03:19 AM
Kramer H
Built and Supercharged 47
Kramer H's Avatar
have you changed your t-stat? have you noticed any leaks on the ground? fill out your vehicle info so we know what you have. v8 or I6? what year? could be a head gasket.
Built Beater 01 WJ
Swapped, SUPERCHARGED Locked, Lifted and Long Armed.
02 Cummins. It has a smoking problem, And it wont quit.
K8 GSXR 1000- Racefit,Comp Werks,Puig,Woodcraft,B2 Industries,55W HID'S, R&G Engineering, Two brothers, ASV, DDM, "The pantie dropper"
Kramer H is offline
post #4 of 24 Old 11-02-2009, 03:25 AM Thread Starter
selim
Vehicle is an 01 grand cherokee laredo I6. It is an australian car so its right hand drive.
When you say leaks on the ground... do you mean the road or the floor of the car, as in under the floor mat!
The reason why I asked is because I have another post which is about my floor being soaking wet!
Also, what is a t-stat.
selim is offline
post #5 of 24 Old 11-02-2009, 03:29 AM
colt808
Bad water pump...probably not moving coolant when at idle. The loss of coolant is pretty slow and likely due to the overheating.
Run your engine to operating temperature and then carefully touch the return hose to feel if its hot. If it is, the t-stat (thermostat) is opening up okay. Wait about 15 minutes and VERY carefully remove the radiator cap. Use a bunch of towels to avoid getting burnt when you relieve the pressure. Once you remove the cap, run the engine again and check that the coolant is flowing. My bet is that the fins on the water pump have failed and the flow will be weak at idle.
When you change the pump, it'd be a good time to flush the system and change the t-stat while you're at it. Don't forget to include the heater lines/core in the flush.
Your wet floor is likely a problem with the evaporator core drain being plugged. Lots of posts about how to fix that, just do a search. Hmm...to be sure though, does the floor smell like coolant? If it does it could be the heater core or blown heating hose/fitting.
colt808 is offline
post #6 of 24 Old 11-02-2009, 03:32 AM
Kramer H
Kramer H's Avatar
could be one of two things. bad water pump as stated, OR bad heater core. any issues with your heating? that wet floor, did it smell sweet? was it coolant on the floor? thats due to a bad/leaking heater core.
Built Beater 01 WJ
Kramer H is offline
post #7 of 24 Old 11-02-2009, 06:08 PM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
With the problem mainly occuring when stopped, I have a feeling it has to do with the cooling fan. I was having the same problem on my '04 and it was a bad fan. The brushes in the fan were worn and not turning the fan at full speed. Of four brushes one of them was so worn that it was not even touching the armeture (SP).
My fan is the 2 speed one. I do not know what you have but one way to tell is to check how many wires are in the connector at the fan. 2 wires is a single speed and 3 wires is a 2 speed. It could also be the fan relay being intermitent.
And I do not think there is any difference in the cooling system just because it is a right hand drive.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #8 of 24 Old 11-02-2009, 06:12 PM
lasvegas
Sounds like a heater core to me. Anytime you need to keep adding coolant, there must be a leak somewhere. Head gasket was my second guesss, but after reading some more, you definately have a heater core issue.
lasvegas is offline
post #9 of 24 Old 11-02-2009, 06:14 PM
michiganmaveric
Got Beer?
2011 JK Wrangler
The wet floor mat could be from a bad heater core, which could account for the loss of coolent, or it could be from a plugged condensate drain for the A/Cond system. As stated if it smells sweet it is probably coolent, which should also have a slight slick feel to it.
T-Stat= engine temperature thermostat.
Lifetime member #13
post #10 of 24 Old 11-02-2009, 06:23 PM
michiganmaveric
Got Beer?
2011 JK Wrangler
Could not a head gasket cause overheating also?
Lifetime member #13
post #11 of 24 Old 11-02-2009, 06:42 PM
lasvegas
yes, it could, but what your describing (wet floor, sweet smell, loss of coolent), I would guess a heater core. Just my guess though. Good luck!
lasvegas is offline
post #12 of 24 Old 11-02-2009, 06:50 PM
michiganmaveric
Got Beer?
2011 JK Wrangler
The OP did not say that the floor water smelled sweet, someone else asked him if it did.
Also this from his original post leads me to think it is a relay problem. He turned off the A/C and turned it back on and everything was OK. "The other day it happened again, and I turned the air-con off and then on again, then the temp gauge did not go over half way which seemed like its gone back to normal." If I am correct, when you turn the A/C on it kicks on the electric fan, if the relay was intermitent this could be his problem. Or it could still be the fan.
Lifetime member #13
post #13 of 24 Old 11-02-2009, 09:20 PM Thread Starter
selim
Thanks for all the replies guys... it seems that I need to do some hard work to get to the problem.
Some new information... due to being 35C degrees here in Sydney!
I drove the car this morning when the temp was about 29C degrees and it seems that on hot days, its more likely to be overheating.
With the A/C on or off when idling at a set of traffic lights... the temp starts going up.
But its wierd because this doesnt always happen. Some days it doesnt go up at all, even though it might be 25C degrees.
Also with the wet floor, I clearly remember that it did not smell like anything at all. To me it looked, felt and smelt like water... but maybe with a little bit of bad odour due to the water sitting there for who knows how long! (when I first discovered the problem)
I hope this information above will help you, help me, to help my car...
cheers,
Selim
selim is offline
post #14 of 24 Old 11-03-2009, 04:04 AM
michiganmaveric
Got Beer?
2011 JK Wrangler
With everything you are saying I am still convinced that it is cooling fan related.
For the water on the floor, one way to check if your drain is plugged is to run the A/Cond and after a little while see if you have water dripping from under the jeep, your drivers side area rear of front tyre, that is where the drain is located. Take it for a short drive and when you stop the water should start to puddle under the jeep. Look at another jeep to get an idea of exactly is is coming from. If you do not see water draining on the ground then your drain is plugged.
If you go to www.jeepslmited.com there are a couple of good write ups with pics about how to change the relay and fan.
Lifetime member #13
post #15 of 24 Old 11-03-2009, 04:09 AM Thread Starter
selim
Ok guys. You are all going to hate me now due to my new discovery.
Today when the car cooled down enough I opened the radiator cap to see that Water was not visible. But, the coolant level was half way so from that I assumed that the water in the radiator would be fine.
Anyways, I filled the radiator up and it took about 1.5litres of water.
After that, I ran the car with the cap off for a little bit and the water love seemed to be going down and coming back up. From this I am assuming that water is flowing fine through the radiator and engine.
Also, I took the switch off the thermostat and put it back on... Thinking the connection may not have been sitting on properly.
So, I drove the car as per normal... With the a/c cranked up and the car did not over heat at all.
So that's tht problem.
Now my next concern is that why does the water in the radiator go low, and collant box stays fine. It use to be the other way around!
What could be the cause for the radiator to get low?
Thanks guys and yes I know... I'm a d#%k h*+d.
Selim
selim is offline
WJ Heating went off Mollerdrengen ZJ Grand Cherokee Forum 14 01-09-2007 11:18 AM
Seat heating does not work, but heating elements are ok WolfgangK ZJ Grand Cherokee Forum 12 04-17-2006 10:44 AM
Is my ZJ over heating? Eds97ZJ ZJ Grand Cherokee Forum 9 06-09-2005 06:30 AM
Ov heating spichman510 ZJ Grand Cherokee Forum 13 11-06-2003 09:47 PM
over heating g0Nzo ZJ Grand Cherokee Forum 1 04-15-2003 02:20 AM
