Over head lights wont turn off - JeepForum.com
post #1 of 25 Old 07-14-2013, 09:39 PM Thread Starter
roundrbn
First i had door lights staying on with overhead lights i changed driver door jam and passenger door jam swithes pulled all four out then pugged them in those lights work properly the overhead cargo lights stay on once imturn the key off i changed the the headlight swith box on the dash board changed courtesy light relay swith in fuse box still they stay on but when i turn key on all interior lights work correctly ran out of options 1996 jeep grand cherokee 4x4 limited 5.2
roundrbn is offline
post #2 of 25 Old 07-14-2013, 11:27 PM
dellis
2005 WK
Did you check the rear hatch class switch? If you take about 4 of the screws just below the window, you can bend the plastic out to get to it.
dellis is offline
post #3 of 25 Old 08-01-2013, 12:00 AM Thread Starter
roundrbn
I took the rear cargo switch and u plugged that and all the door switches and the overhead cargo lights still stAy on??? Oh and my rear glass does not open
roundrbn is offline
post #4 of 25 Old 08-01-2013, 01:52 PM
Oldfrog
2007 WK
This may or may not be relevant, but I found a pinched wire inside my overhead console once. But it made them flicker...not stay on.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #5 of 25 Old 08-16-2013, 04:00 PM Thread Starter
roundrbn
If it were a short they wouldn't work properly whn the key is on I'm out of options
roundrbn is offline
post #6 of 25 Old 08-16-2013, 05:10 PM
JacoToTheB
Does your VIC ever say your back hatch is open? I had that problem where the lights would stay on. If you open the back hatch and press the cargo light it turns off all interior lights.
'97 ZJ
K&N drop-in & Slow
F150 F>R (The link below because I couldn't figure out how to hyperlink...)
http://www.jeepforum.com/forum/f13/my-jeep-build-infamous-f150-coils-1767489/
JacoToTheB is offline
post #7 of 25 Old 02-20-2014, 08:03 PM Thread Starter
roundrbn
I have changed all switches in the jeep my Vic shows nothing open when I turn truck off and take key out overhead lights stay on? I have changed out the light switch panel made sure door jams were working but still interior light stays on I have to pull he fuse when key out if ignition when key is in ignition the switching works correctly gonna try changing the ignition relay
roundrbn is offline
post #8 of 25 Old 02-20-2014, 08:07 PM
i6zombiejeep
I had this too. My lights wouldn't shut off. I fixed one of my switches in the rear passenger door which fixed the it partially, then i found and fixed a pinched wire in the overhead console which solved the issue completely.
i6zombiejeep is offline
post #9 of 25 Old 02-20-2014, 08:11 PM Thread Starter
roundrbn
Well originally the Vic showed doors open and overhead light was on changed the door jam switches all around even did overhead console switch and the Vic was good showed no doors open but overhead lights still on changed dash board light switch and light resister switch on floor panel still overhead lights stay on when truck is off and key is out but (when the key is on all lights work correctly so I'm gonna change the ignition relay switch next my last option ?
roundrbn is offline
post #10 of 25 Old 02-20-2014, 09:04 PM
Gearhead31
isn't there a timed relay that controls the lights? Makes them stay lit only for xx amount of time during certain situations then turn off..
1995 ZJ ltd, 4.0 i6, *cough stock cough* 253,xxx and still pumping strong
1998 Chevy Cheyenne K1500, 5.7L Vortec, mostly stock
*In peace, sons bury their fathers. In war, fathers bury their sons. - Herodotus
Originally Posted by JasonStebbins
We can call it the Whoosh King Catalog System. :D
Gearhead31 is offline
post #11 of 25 Old 02-20-2014, 11:32 PM Thread Starter
roundrbn
Yes there is a dimmer switch I changed that first still overhead stayed on
roundrbn is offline
post #12 of 25 Old 02-21-2014, 03:03 AM
Oldfrog
2007 WK
Hmm.....I turn my key off..and open my door...the overhead lights come on. (Normal.)
They dont go off until I lock the doors. ( normal).
They also go off after 5 minutes...without locking the doors. ( normal)
But I can get another minute ( or maybe it's another 5, I forget) when I punch the rear cargo light housing ( switch).
I wonder if your issue is in the rear cargo light area or the controller that it's signaling.
Oldfrog is offline
post #13 of 25 Old 02-21-2014, 06:02 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Timed function is in the bcm. He never said he pushed the light switch,only that he disconnected it. It maybe that the switch in the open position {disconnected} keeps the light in the on position. There were some whacky switching going on in normal operation if I'm not mistaken. Got to go to work, when I get home I'll look at the diagrams, if someone doesn't beat me to it.
Originally Posted by HighLonesome
coralman is offline
post #14 of 25 Old 02-22-2014, 02:05 PM
1998_ZJltd
You unplugged the wrong plug it sounds ..
1998_ZJltd is offline
post #15 of 25 Old 02-22-2014, 07:15 PM
coralman
coralman's Avatar
Sorry I took so long. The bcm does rely on the liftgate/liftglass sense circuit to time the lights staying on or off looks like. This can be bypassed by the cargo light disable. What I post wont do you much good without visual images. Looks like the disable takes the courtesy lamp relay out of the circuit { controlled by the bcm} and keeps the lights on. But if either liftgate or liftglass switch is stuck open with the disable off the lights will rely on the bcm timer to cut them off.
Name:  cargo lamp disable.jpg
coralman is offline
