Outer bearing and seal numbers? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Outer bearing and seal numbers?
All Bilstein shocks & struts - Lowest Prices Ever and Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffstuff Axle Simple Swap Kit!
Unread Yesterday, 10:39 AM   #1
Dubfire98
Looking for a definitive answer as to where i can find OUTER axle bearings and seals for both the Dana 30 and the 44hd. I had recently purchased master rebuild kits from G2 but they do not come with the outer seals and axle bearings. Just trying to get everything together so my installer can set up the new diffs and knock out the rest while its apart.
TN JEEPER
Dubfire98 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 11:08 AM   #2
Dubfire98
Maybe im mistaken. I need the inner axle dust shields along with axle seals and bearings. Put it like this, i have everything thats inside the pumpkin itself.
TN JEEPER
Unread Yesterday, 11:35 AM   #3
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
You can get the inner seals for the D30 anywhere like napa, etc, rear does not have inner seals. Or online...
http://www.4wheelparts.com/Drivetrai...neEaArRC8P8HAQ
Here is the outer bearing for the D30
http://www.amazon.com/Timken-513084-...grand+cherokee
Here is the axle/seal kit for the D44a
http://www.jeep4x4center.com/r1563ta...rp-ak1563.html
Should be everything you need along with the correct master kits unless the spider/side gears need replacing. Your ZJ year is the changeover year from CJ to TJ style front pinion, so be sure you get the right kit for the front.
HighLonesome is offline   Reply With Quote Quick reply to this message
