Ordered My Kolak Tune Up Kit - JeepForum.com
post #1 of 18 Old 09-12-2010, 04:15 AM Thread Starter
torchd
2003 WJ
Had couple questions..
I have never dealt with a cap and rotor (did a search), but how do you take it off? I knw it's held on by 2 bolts. How do I take that rotor off? Sorry guys, I have been spoiled with coil packs or COP all my life
Do I need to put any die-electric grease on anything?
Should I use anti-seize in the threads of the spark plugs?
Thanks for the help
1998 Jeep Grand Cherokee Laredo
2" BB Pucks | SkyJacker Hydro Shocks | Rubicon Wheels | Cooper 245/75/16 Tires
2002 Trans Am
Cam, Full Exhaust, Stock Heads, Stock LS6 Intake and Stock 10 bolt with 3.42s
420 RWHP and 382 RWHTQ
torchd is offline
post #2 of 18 Old 09-12-2010, 04:57 AM
jackitorslamit
rotor and button just pops right off. a touch of anti-seize will help with future plug changes but some people don't. just remember where each plug wire goes.
jackitorslamit is offline
post #3 of 18 Old 09-12-2010, 06:57 AM
sadass
2x on the rotor, just pull it strait up. And most important, do your self a huge favor and Mark your plug wires and cap well before you pull the wires. I use white tape and clearly mark both wires to plug numbers and wires to cap positions. I even use a marker and write on the cap. keep in mind the wires are not all the same length.
I make many water crossings, so to help keep water from stalling my motor, I also run a thin bead of silicon on the cap edge or seat,
And last but not least, before installing Always check your spark plug gap. If need be you can buy a gaper from any auto part store for @1$dollhair if you do not have a feller gauge.
5NineZJ,35mtr/k IRO 7" LA F/R Detroit F/HP-4.56 R/Aussie 44A. ARB Snorkel/JRC Sliders/ Protofab w/9500S./Bushwhackers. Novak242 TCcable.
sadass is offline
post #4 of 18 Old 09-12-2010, 10:29 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
don't use antiseze, it has copper in it and when it melts out can cause all sorts of arcing issues.
use a non conductive grease(supplied in most wire kits) on the boots so you can remove them easier.
ratmonkey is offline
post #5 of 18 Old 09-12-2010, 11:55 AM
Blown5pnt4
How much is it and what is including in this Tune Up Kit ? I'd like to do one on my Jeep as well.
"When Lightning Strikes The Heartbeat Stops"
2001 F-150 Lightning #6065 of 6381 Built 08/09/01
Blown5pnt4 is offline
post #6 of 18 Old 09-12-2010, 02:45 PM Thread Starter
torchd
2003 WJ
Originally Posted by Kolak
Hi,
Here's all the information about my Kolak Ignition Upgrade for your 1998 ZJ I6:
My recommendations for the 4.0 ZJ ignition system are designed to improve idle quality and throttle response, and to improve and maximize current transfer. This really helps support other modifications. Here's what I recommend:
Magnecor KV85 ignition wires
MSD high output replacement coil
Coil adapter harness for '98+ Jeep
Heavy duty US made brass terminal distributor cap with rotor
Autolite platinum plugs
Price for the kit is $210.00.
JeepForum members get 10% off the price of the kit.
If you'd like to get the kit, I just need your zip code to calculate shipping charges.
Thanks
Kolak
Seems like a well put together kit
2002 Trans Am
torchd is offline
post #7 of 18 Old 09-12-2010, 02:46 PM Thread Starter
torchd
2003 WJ
We are not talking about the spark plug boots. We are talking about putting anti-seize on the threads of the spark plugs....
2002 Trans Am
torchd is offline
post #8 of 18 Old 09-12-2010, 02:47 PM Thread Starter
torchd
2003 WJ
Yes I do know to mark each wire and the cap before pulling the old stuff off, and of course I will need to gap the plugs before I put them in
2002 Trans Am
torchd is offline
post #9 of 18 Old 09-12-2010, 03:30 PM
Blown5pnt4
Hmm thanks for the info. Sounds like a nice kit.
post #10 of 18 Old 09-12-2010, 04:30 PM
stageninja
That Rigger Guy
stageninja's Avatar
When I ordered mine Kolak said US made cap and rotor but it clearly says Made in Mexico on the cap I recieved. That would technically be made in one of the Americas but not in the US. I am happy with the performance though.
Mine '97 White, ZJ Ltd, 5.2, Up-Country Suspension, Kolak ignition, Kolak/Magnaflow Exhaust
Her's '98 Chargold ZJ Ltd. 4.0 2wd
Our 1st '97 White, ZJ Ltd, 5.2, The parts Jeep for 5 years...R.I.P. Sent to Pic-A-Part 5/17/2013
stageninja is offline
post #11 of 18 Old 09-12-2010, 06:47 PM
Kolak
Vendor
Kolak's Avatar
I use the Borg Warner Select cap and rotor in my kit - the quality is excellent. They moved some manufacturing to Mexico some time ago. Guess I need to reword my description but there is no change in the quality of the components.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #12 of 18 Old 09-12-2010, 06:53 PM Thread Starter
torchd
2003 WJ
Nick.. Do you recommend anti-seize on the plugs and some die-electric grease on the rotor?
2002 Trans Am
torchd is offline
post #13 of 18 Old 09-12-2010, 07:15 PM
Kolak
Vendor
Kolak's Avatar
Yes - always a good idea.
or
Kolak is offline
post #14 of 18 Old 09-13-2010, 12:59 AM
melk
Any chance I could buy just the wires and MSD coil from you? I've already put fresh plugs and cap/rotor on it.
melk is offline
post #15 of 18 Old 09-13-2010, 01:27 AM
Kolak
Vendor
Kolak's Avatar
Absolutely! Just send me a PM to remind me to price that for you.
or
Kolak is offline
Kolak Richtdu89 ZJ Grand Cherokee Forum 30 04-09-2015 10:13 PM
Thanks Kolak!!! avis1055 ZJ Grand Cherokee Forum 31 08-11-2009 06:33 AM
Where is Kolak? IRPerformance ZJ Grand Cherokee Forum 17 08-21-2008 03:06 AM
Kolak wassy ZJ Grand Cherokee Forum 14 12-12-2006 10:18 PM
Gibson vs. Kolak?? fiddlyD ZJ Grand Cherokee Forum 10 11-14-2004 09:29 PM
