Quantcast Operation: Former "Anti Minivan Style ZJ" into Lifted + BFG's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Operation: Former "Anti Minivan Style ZJ" into Lifted + BFG's
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp Series
Old 11-11-2007, 10:49 PM   #1
redhatman
So guys and gals as you know I have been debating on tires and lift combinations for quite some time now. Well I finally locked down and decided on the IRO 3.5" Lift for my ZJ, along with some BFG A/T's. I picked up the BFG's today slightly used, with 5 tires one being new. You can see from the pics how much wear are on them. They are 245/75/R16's so I will use them on my Stock wheels, and maybe get some Spidertrax spacers when money allows. Anyway, it should be said and done by next Sunday Night, my next available night to install. Here are before pics, let me know what ya think! Btw, mud flaps are going I assume. Also a big mile marker being I just reached 150,000 miles, but from what I hear I got another 100,000 miles on this engine to go with no problems.
Before.
Tires:
Penny and Quarter on a used tire:
The 1/5 only new tire, will be my spare. Still has the "Fuzzy things" so I know its new. Notice the tread is about 3 lines before the 1/2 inch mark.
Now, a used tire. A bit more fuzzy, but the line is nearly in the same place.
These came off of a Wrangler that got a bigger lift and 35's so he didnt really run on them at all before changing tires.
Like I said, plan is to lift 3.5" via IRO, and then these tires should add another 2-3 inches I assume.
Let me know what you all think!
-Pat
-Pat I'm 19, and getting my hands cut while learning
"Project Dirty Princess"
5.9 ZJ 7" IRO, 35s, 8.8, hp30, locked, blah blah
"Project Grow A Set"
Originally Posted by CMARJEEP View Post
Those tires look freakin awesome Redhat... took the ZJ up a notch in my book. Now you're at notch 2.
Looking for quality Jeep parts? www.ironrockoffroad.com
redhatman is offline   Reply With Quote
Old 11-11-2007, 10:56 PM   #2
redhatman
For some reason, the no clicky link deal wont work so I am sorry, but I tried html and IMG code.
Old 11-11-2007, 11:25 PM   #3
Sporer65
Location: Powder Springs, Georgia/University of Tennessee
Before.
Tires:
-Pat
No Clicky. Did you buy new rear springs? Because with the I6, they won't give you the same about of lift in the rear. And the tires will give you about 1" more lift. You had 29"s or so, going to 31"s, that is a 2" difference. Since that is total diameter, you have to divide in half and you get a 1" lift.
Ben
1993 Jeep Grand Wagoneer ZJ V8: Rear Aussie, 3.5" Lift, 31" M/Ts
GA Trail Riders
Sporer65 is offline   Reply With Quote
Old 11-11-2007, 11:32 PM   #4
redhatman
I am getting the IRO kit here: http://www.ironrockoffroad.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=IROR&Product_C ode=IR-Z_3LK&Category_Code=PFZ
Oh yeah, makes sense. So I assume 4.5" lift total? Does swapping the front to rear, and news in the front really lift it that much?
Old 11-11-2007, 11:44 PM   #5
Sporer65
Yes it does, but only if you have the V8. With the I6, its only going to lift it like 3"s or so. I would buy some new front V8 springs, probaly Up-country, or new rear springs.
Like these: http://www.ironrockoffroad.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=IROR&Product_C ode=IR-Z3RSP
Ben
GA Trail Riders
Old 11-11-2007, 11:50 PM   #6
redhatman
edit, never mind. A T-Case Drop shouldnt be neccesary right?
Old 11-12-2007, 04:46 AM   #7
ben_wagner
1994 ZJ
Nope. Not necessary at all.
1994 Grand Cherokee Laredo 4.0 I6 4x4
4.5" IRO, 32" BFG A/T KOs
ben_wagner is offline   Reply With Quote
Old 11-12-2007, 04:50 AM   #8
ben_wagner
1994 ZJ
Disclaimer: If you install the lift and find that there are bad vibes, you may need the transfer case dropped, but it should be the last thing you do. You lose about an inch of clearance or so.
It all depends on your individual setup. Some ZJs handle lifting just fine while others find all sorts of problems.
Old 11-12-2007, 06:45 AM   #9
redhatman
I guess that could be the case, I assume in your 4.5" you did need a drop?
Old 11-12-2007, 06:50 AM   #10
Reswob
Even V-8 springs won't guarantee you 3.5" I only got ~3" with mine.
'98 ZJ Laredo 5.2L Selec-Trac ~ Rock crawler on the outside, luxo-cruiser on the inside
3.5" IRO lift // 31" Cooper STT's // D44a Aussie Locker // NP242 swap // KOR Tow Shackles
'08 Kawasaki Ninja 250R ~ Daily Driver, 50 mpg Speed Demon
#27. Shirts get dirty. Underwear gets dirty. Pants? Pants never get dirty, and you can wear them forever.
Reswob is offline   Reply With Quote
Old 11-12-2007, 09:16 AM   #11
RyanZJ
I got more like 4.5" in the rear with my V8 UC springs. Worst case scenario you'll have to buy some 3/4" spacers for the rear if it sits too low. Not a big deal...they're only like $10.
Ryan
'98 ZJ V8 Limited
'06 WK V8 Laredo
'51 CJ-3A
RyanZJ is offline   Reply With Quote
Old 11-12-2007, 09:22 AM   #12
QuadraTokn
1930 WJ
http://www.jeepsunlimited.com/forums/showthread.php?t=858518
I have a modified 1999 WJ and a stock 2001 WJ
Tread Lightly
Pictures
PARTED OUT 8 WJ Grand Cherokees ! ! ! ! ! !
QuadraTokn is offline   Reply With Quote
Old 11-12-2007, 09:35 AM   #13
BLACKzj52
u said ur ditching the mudflaps?
wanna send em my way??
- John - 22 and learning <-- ORIGINAL
-Black 96 ZJ Limited 5.2L V8 lifted 5" and blacked out with some fun stuff
My Build Thead
Facebook
RIP Troy Edwards
BLACKzj52 is offline   Reply With Quote
Old 11-12-2007, 10:52 AM   #14
tjsgrecc
not to big on the ZJs but those size tires should fit with out an lift at all... maybe a little trimming required but thats cheaper than an IRO or just get a BB for way cheaper. my
2000 Black WJ w/ I6, Selec-Trac | Tow-Hooks | Transfer Skid Plate | 2.5" KOR BB | SkyJacker 8000 Nitro Shocks | 245/75R16 Kelly Safari MSRs | 2 Eclipse amps | MB Quart 12" Sub | Phoenix Gold Speakers F/R | Pioneer MP3 Deck |
tjsgrecc is offline   Reply With Quote
Old 11-12-2007, 05:27 PM   #15
ben_wagner
1994 ZJ
Sorry it took so long to get back. No, even at 4.5" I don't need the drop. It's sitting in my garage back home.
Glock Forum
