only one power window not working - JeepForum.com
post #1 of 3 Old 12-21-2003, 08:06 PM Thread Starter
EYPUFF
EYPUFF's Avatar
well, i'm just about ready to give up and take the jeep to the "stealer-ship". I've spent many hours looking for tears, ripps, in the wiring and the connectors. anyhow, here's the scenario. last summer i noticed that my driver side REAR window wouldn't go up. i sucks, because when you think all your windows are up you get out and see that the one window you can't see from the driver seat is down. now i gone had it with the window, so i tore off the door panel and took a look at the control console thing. took out the connectors and put them back in. i traced the wiring harness to the side of the car which then i disappears. but yah, now that's it the winter, rain starts to get in and i forget that the window is open. like the window works it goes up and down... from that switch only. not the master. at first i thought it might be a fuse, but all the others work, so i ruled that out. and well im just about to give up. but before i do, i thought i'd give the boards a shot. so there it is. any solutions? suggestions? comments? sarcasms? etc.... ?
well thanks in advance.
EY
1995 GC 5.2 Limited V8
Green Jeep Club Member # 32
EYPUFF is offline
post #2 of 3 Old 12-21-2003, 11:48 PM
moabster
moabster's Avatar
2011 WK
Have you checked the wiring harness connected to the drivers door? This is a common problem area. The harness was built a little too short and after a few years some of the wires will break. Since all of the windows can be controlled from the drivers door there is wire for each window in the harness. To check it, open the drivers door and locate the rubber boot that covers the wiring harness. Remove the boot from one end and inspect the wires. You may find several that have split insulation and/or complete breaks. To fix them you will need to solder in a short piece of wire to any breaks and cover it with heat shrink tubing.
Some people avoid more problems by removing the entire harness and rebuilding it with new wires all the way to the connectors.
Good Luck.
2000 Jeep Grand Cherokee V8 Stock
93 YJ I6 hard top (really belongs to SPEED)
RE 4.5" Extreme Duty Lift, Advanced Adapters SYE, Tom Woods CV Drive Shaft, EA589 10" rims with 33" x 12.5" MT/Rs
Bullet Proof Front and Rear Bumpers and Tow bar
moabster is offline
post #3 of 3 Old 12-27-2003, 12:16 AM
REDDOG55
it is the wire harness...the same thing happend to me in the rain...a new one would be a lot of $$....i had mine redone
REDDOG55 is offline
Passenger-side power window not working. Interior lights wont turn off Saxidani ZJ Grand Cherokee Forum 2 03-29-2009 10:22 AM
Driver's Window/Door control are not working. Jim Holmes ZJ Grand Cherokee Forum 5 12-24-2008 10:18 AM
99 WJ passenger window not working Slap-Bassist531 ZJ Grand Cherokee Forum 11 06-11-2008 12:33 PM
Window/door locks not working carilynn77 ZJ Grand Cherokee Forum 1 04-15-2007 08:29 PM
Side window defroster vents not working? John in MA ZJ Grand Cherokee Forum 3 09-04-2006 10:10 PM
