One More Question Regarding 96 Grand Cherokee AC Water Leak - Pass Side - Page 2 - JeepForum.com
post #16 of 20 Old 07-25-2013, 06:38 PM Thread Starter
musec07
Hello ElCamino ManT ...Your fix looks better than the highly shared one I've seen... Please do remember to get those specs! If you advertiose your work on radio ...I'll make you a custom radio spot that will stand out in your market. That's what I do for a living! I'll be happy to trade!
musec07 is offline
post #17 of 20 Old 07-25-2013, 06:54 PM
ZeeJay1997
Originally Posted by ElCaminoManT View Post
i ran a piece of hose out into the fender well so the water wouldnt be draining thru the 'frame rail'.
Wouldn't water go into the drain and frame rail when running on a wet highway? Mud clog the drain?
I think the reason they made it drain into the frame rail was to keep it from getting plugged.
ZeeJay1997 is offline
post #18 of 20 Old 07-26-2013, 12:55 AM
ElCaminoManT
sorry, i just got home from a VERY long day. ill do my best to get the measurements tomorrow when i still have some light to see what im doing.
doubt it, its not in the path of water and mud that is being flung from the tire. then again, the amount of water and mud that we deal with out here is a LOT less than others see around the country. i suppose if you wanted to get really fancy, id bet there is a preformed hose piece somewhere out there that would make it possible to come out into the fender and then point down for further protection and one could seal up the hole around the hose with silicone or something to keep the frame rail dry
1993 Jeep ZJ Laredo 4.0L/42RE/242/D30/D35
ElCaminoManT is offline
post #19 of 20 Old 07-26-2013, 09:13 PM
ElCaminoManT
here ya go. guess i got lucky but its 4 inches to the center of the hole you want to drill from the access hole for the upper suspension arm bolt and 1 inch out from the seam in the body
post #20 of 20 Old 07-27-2013, 09:30 AM
RoldGold
Thank you! Can't get much clearer than that!
1996 Grand Cherokee Limited 4.0L
PSC Steering Gear; NP249 w/ new VC; Moog TRE's, Track Bar, Stabilizer bar bushings and endlinks, control arm bushings
Still no lift, and almost no paint on the hood
RoldGold is offline
96 , cherokee , grand , passenger , water leak
