Onboard computer display not working - JeepForum.com
post #1 of 3 Old 07-13-2011, 07:05 AM Thread Starter
95_ZJ_Limited
Hey all, A couple of nights ago my ZJ started acting up, onboard display was going crazy, A/C display was off and only blowing towards my feet, and I had no radio and finally when I turned it off, the security light began flashing (I had not locked it) and you could hear a ticking or clicking noise coming from around the fuse box. Also, the interior lights were flickering and dim. I replaced fuse #16 I belive which was a 15 amp fuse with a 20 amp (I figured this could be because of my aftermarket radio head unit) and immediatly the security light stopped flashing and I regained control of the A/C and radio. After checking every other fuse, I still cannot get my onboard display to even show anything anymore. Any help on this would be greatly apreciated.
Thanks,
Bryan
1995 ZJ Limited. Lifted, AW4 & 4X4 swapped
Build Thread: Jeep Grand Hilton
Built Not Bought # 529
95_ZJ_Limited is offline
post #2 of 3 Old 07-20-2011, 11:02 AM
PlazJ
1994 ZJ
My computer display also went out last night on my 94 GC. Just before shutting down I noticed faint red horizontal lines accross the entire display. "not good", I thought. Later when I went to leave and started backup, the display began lighting up indicators I never knew it had. It flashed on and off a couple of times then went out completely with a faint burning smell.
Guess I'll be pulling the unit out some time to attempt a repair. Clearly the power supply or some of the circuity burned. As long as no exoctic irreplaceable parts are destroyed, I should be able to return it to it's former glory. I've loooong experice at electronic repair.
Write up maybe? Or does one alredy exist somewhere?
PlazJ is offline
post #3 of 3 Old 07-20-2011, 12:34 PM
MaintMech
Old and in the way
MaintMech's Avatar
I've got these bookmarked, maybe they will be of use to you.
http://www.jeepforum.com/forum/f13/c...moval-1228233/
http://www.jeepforum.com/forum/f13/c...-fixed-175207/
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
Originally Posted by coralman
If the faith isn't there,the doubt is.
MaintMech is offline
VIC display not working chadteetzen ZJ Grand Cherokee Forum 4 01-13-2011 04:29 AM
Radio Display not working bav278s ZJ Grand Cherokee Forum 3 08-01-2010 09:43 PM
96 v8 limited basic onboard computer swap question pajeeper1123 ZJ Grand Cherokee Forum 3 11-20-2009 10:49 AM
94 Grand Infinity Radio Display Not Working savage2506 ZJ Grand Cherokee Forum 3 02-29-2008 08:59 AM
94 Jeep Grand limited computer display Kornchild ZJ Grand Cherokee Forum 3 12-13-2001 03:49 PM
