OMG ZJ on 42" tires!!!! - JeepForum.com
post #1 of 16 Old 11-04-2010, 09:34 PM Thread Starter
Erbo1Kanerbo
I have a problem... i knew the title would get ya. When i am going down a hill and i let off the accelerator my rpms will bounce. It will bounce up to about 1500 rpm then go down to about 1000 rpm then it will go back up to 1500 this is going about 50-60 mph if someone could help me out id really appreciate it thanks...
i felt bad for the title so heres some pics of the outlaw offroad zj my personal favorite idk if its on 42's or not lol
ZJ Build thread:
ZJ's: If you dont know what it is you cant afford it.
Erbo1Kanerbo is offline
post #2 of 16 Old 11-04-2010, 09:40 PM
98BlackZJ
Was your battery disconnected recently? Mine does that for about 100 miles after the battery is disconnected. I think its the computer relearning the shift points.
98' 5.2 ltd, 4.5" lift, 33x12.50 KM2's, Clayton's longarms, 8.8/HP30 Aussie F&R
98BlackZJ is offline
post #3 of 16 Old 11-04-2010, 09:41 PM Thread Starter
Erbo1Kanerbo
nope its been connected for a while
ZJ Build thread:
post #4 of 16 Old 11-04-2010, 11:43 PM
paintball10148
hmm i know that when my TPS went out my rpms had a mind of their own.. are there any other strange things goin on? and since you tricked me into this thread ima comment haha its nice to see that the outlaw isnt a trailer queen and that it actually sees some wheeling.
1997 zj 4.0 np242 5.5" iro lift. 33x12.5r15 khumo mtrs.---- rolled and sold :'(
1997 zj ltd 4.0 np249 black np 4" rough country lift 33x12.5r15 mtrs.----sold
1999 xj sport 4.0 np242 waiting for 4.5." Lift and 33s :D
paintball10148 is offline
post #5 of 16 Old 11-05-2010, 01:32 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Those rpm are really low for that speed. Really low. What tires you running?
ratmonkey is offline
post #6 of 16 Old 11-05-2010, 09:16 AM Thread Starter
Erbo1Kanerbo
its not exact rpm but its real close, im still running 235/75/15's im trying to get everything sorted out before i put bigger tires on. i know something is messed up with my driveshaft too because i feel a resistance when it is in and when i slow to a stop a can hear a whining noise.
ZJ Build thread:
post #7 of 16 Old 11-05-2010, 10:51 AM
clemsonyj
Coil or TPS. My coil went out and did the exact same thing. Idle surged while moving.
Max
91 YJ: 2.5L, 31 A/T's, Crager soft 8's: SOLD
94 ZJ 5spd: RE 3.5" Superflex Kit, HPD30, Lockright, 32 Maxxis Bighorns, Rhino-lined Floors, Homebrew Sliders, Hacked fenders: SOLD
98 ZJ: 5.2L, RC Budget Boost, 16" Moabs, Goodyear MTR's, NP242, Magnaflow 3"
clemsonyj is offline
post #8 of 16 Old 11-05-2010, 11:21 AM Thread Starter
Erbo1Kanerbo
what coil? when i think coil i think of the springs lol. i know its prob something electric but where i can i find some info on this
ZJ Build thread:
post #9 of 16 Old 11-05-2010, 12:41 PM
JFox21
Ignition coil.
Jamie
Sophomore at Santa Clara University
JFox21 is offline
post #10 of 16 Old 11-05-2010, 01:01 PM Thread Starter
Erbo1Kanerbo
i thinks its time to pull the trigger on that kolak ignition upgrade then...
ZJ Build thread:
post #11 of 16 Old 11-05-2010, 04:25 PM
ZJPunk98
Check, clean, or replace you idle air controller.
ZJPunk98 is offline
post #12 of 16 Old 11-05-2010, 09:42 PM Thread Starter
Erbo1Kanerbo
already cleaned my iac
ZJ Build thread:
post #13 of 16 Old 11-07-2010, 12:53 PM
clemsonyj
Seriously? Your car has an ignition coil....
Max
post #14 of 16 Old 11-07-2010, 04:10 PM
TheAngus
TheAngus's Avatar
ignition coil on a v8 is at the front pass side of the engine block...right between the battery and the motor
1998 ZJ Limited 5.9L l Vortech Supercharged l SCT, 42lb Bosch, 255lph l Kolak 3" Exhaust w/ E-Cutout l KOR TB Conversion l Addco Swaybars F/R l JKS Rear TB l ORO U-Turn Steering w/ OME stabilizer l RE 4.5" Springs and Monotube Shocks l IRO Rear CAs l Kolak Ignition l Clayton Fronts l
TheAngus is offline
post #15 of 16 Old 11-07-2010, 09:05 PM Thread Starter
Erbo1Kanerbo
no i was joking... sorry im not a mechanic but thats why im on the forum, to learn. if someone had said ingnition coil i would have known. i dont know very much about stuff under the hood
ZJ Build thread:
2" BB, 5" wheel spacers, 16x7 wheels...biggest tires? TX02WJ ZJ Grand Cherokee Forum 9 07-07-2010 02:15 PM
15" with 4.5" backspace and 12.5" wide 33" tires. Rub? bjl95mustang ZJ Grand Cherokee Forum 6 05-07-2008 10:32 AM
3" BB kit installed with 31" tires. some questions about springs and alignment! slagehammer ZJ Grand Cherokee Forum 17 04-26-2008 04:37 AM
Anyone running stock 16" rims and 4.5" of lift? What size tires do you run? bjl95mustang ZJ Grand Cherokee Forum 5 02-12-2007 12:23 PM
Pics of WJ's on 15" rims 32+" size tires Clayton00grand ZJ Grand Cherokee Forum 1 02-22-2006 08:25 AM
