OME Trim Packers and Rusty's Extended Rear Links - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > OME Trim Packers and Rusty's Extended Rear Links
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Jspec Suspension BLOW-OUT FEBRUARY ONLY!! HURRY UP!Income tax season is upon us. We got what u need
Unread 03-10-2009, 12:44 AM   #1
MagnutsWJ
Okay, two questions....
#1- I installed an OME HD kit, with trim packers. i bought the kit used, so no instructions. Rocky Road's IM tech support told me to put the trim packers in like a BB, but now i find out they should be above the above the upper coil seat (whatever its called). Question is: does this pose any problem, being in the wromg spot and do i need to change it?
#2- i also have rusty's extended rear sway bar links, but have not yet installed them. I'm sitting at about 2.5" in the rear. How will the swap to extended links change the ride if any at all?
MagnutsWJ
04 WJ Laredo 4.0
OME HD kit, 255/75/17 Silent Arnors, Addco rear Sway, JKS Track Bar, JK Wheels, Rough Country SS, Intake, TB Spacer, Custom swing down tire carrier, Stillen rotors/pads
http://www.jeepforum.com/forum/f197/...build-1169731/
MagnutsWJ is offline   Reply With Quote Quick reply to this message
Unread 03-11-2009, 02:28 AM   #2
MagnutsWJ
no one? come on...bump
MagnutsWJ
04 WJ Laredo 4.0
Unread 05-08-2009, 11:19 AM   #3
drespecki
1983 CJ7
I am looking for some answers to this as well.... Where can I get some HD rear end links that are like the original ones as compared to the skinny aftermarket ones with the slide on sleeves? They need to be a little longer than the originals because I have the OME HD rear springs and 3/4 of trim packers for a little lift....
It only hurts while you're breathing..
drespecki is offline   Reply With Quote Quick reply to this message
