OME Lift Question.. - JeepForum.com
post #1 of 5 Old 06-22-2009, 12:43 AM Thread Starter
jasn1981
OME Lift Question..
I have been searching the fourms, and can't find this answer. I found someone that had the same question, but it was never figured out...
I have a 2002 WJ with a 1.5" HD Full (Shocks and Springs) OME lift kit. Am I able to add a 2" BB spacer kit to that, and get 3.5" without all kinds of more money thrown at it?
I like my WJ how it is, but after a bit I get bored, and want it HIGHER!!!
2002 WJ 4.7L V8 W/Selec-Trak: 2" OME Lift W/32's
Gibson Exaust, K&N Cold air intake
jasn1981 is offline
post #2 of 5 Old 06-22-2009, 01:54 PM
tozar
I have the OME HD springs with 3/4 inch spacers and needed longer travel Pro comp MX6 shocks than what is required for stock suspension so you'll probably need shocks. The measured lift from hub to fender is 3 inches (18.5 stock to 21.5 lifted) with this lift and it leveled out the front to back which is nice.
Unless your springs have settled a lot, you'll be at about 4-5 inches of lift over stock with 2 inch spacers. You should just get 4 inch springs all around with new shocks.
-- Roy
tozar is offline
post #3 of 5 Old 06-22-2009, 03:53 PM
GraKee99
Rapist Wit
GraKee99's Avatar
If you throw the BB in there, at minimum should get a front adj. track bar, appropriate length shocks, either appropriate length front end links or quick disconnects, and rear sway bar links that are the correct length if you want a rear sway bar.
You have to more than shocks and springs at 4". The minimum you should keep the stock front track bar is 2.5". 3" is pushing the limits of it and one should be bought and also the end links will not be at the best angle.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #4 of 5 Old 06-22-2009, 06:58 PM Thread Starter
jasn1981
Thanks. Seems like it's not really worth doing then. I don't NEED it, and I've already sspent over $600 on my current setup. I don't see any logical way of doing it other than just a full new kit, and in that case I might as well go even higher.
I just want a little more though... so sad...
jasn1981 is offline
post #5 of 5 Old 06-22-2009, 07:05 PM
TMCXJ
another one bites the dust - victim of liftitis
"...a long habit of not thinking a thing wrong, gives it a superficial appearance of being right, and raises at first a formidable outcry in defense of custom. But tumult soon subsides. Time makes more converts than reason." Thomas Paine
TMCXJ is offline
Another lift question limited_pit ZJ Grand Cherokee Forum 2 03-21-2009 09:48 PM
lift question. thinking of going bigger and now i am slightly confused about old lift Irish_Assassin ZJ Grand Cherokee Forum 12 01-22-2009 01:17 PM
Lift Question - NO ITS NOT THE SAME OLD QUESTION - i hope Intense-Dakota ZJ Grand Cherokee Forum 15 02-08-2008 03:22 PM
96 ZJ lift question gvsustud22 ZJ Grand Cherokee Forum 1 05-25-2007 01:22 PM
Lift question... nierace ZJ Grand Cherokee Forum 14 11-30-2006 03:29 PM
