old subject new questions...ZJ electric fan conversion - JeepForum.com
post #1 of 20 Old 12-27-2008, 05:01 PM Thread Starter
abswa
Hey y'all,
I've been contemplating the ZJ electric fan conversion for a while now after going through 3 fan clutches and 3 water pumps over the last 5 yrs.
From what I understand, the conversion using the parts from a 98 5.9 is the best, but also the most expensive. So obviously the Taurus conversion appeals a little bit more to me.
Here are my hick-ups:
a) I would like to do this conversion with a temp sensor in place so the fan runs automatically and
b) all the diagrams I saw require to some electrical connection to the AC compressor.
My AC has not been working ever since I got my ZJ ( the clutch engages if you power the leads at the compressor, but the switch in the dash won't do that ... the switch in the dash for the AC wont do anything at all except turn on the little green LED) and I neglected the AC anyway because I never use it. Maybe it is time to take the compressor out altogether, install a shorter belt and get a little better mpg.
So my big thing now is: Has anybody done a conversion which utilized the Taurus fan, used some sort of temp sensor to activate it automatically when needed and has anybody done this without any connection to the AC compressor.
Thank to y'all for all your help.
252k miles and not ready to die
# 2001 Yamaha FZ1 # 2006 BMW R1200RT #
RED JEEP CLUB MEMBER #516
abswa is offline
post #2 of 20 Old 12-27-2008, 05:16 PM
Eldoradoman
Item # 170288559565 on eBay. Get this, it's all you need.
1998 Bright Platinum 5.9, 242 swap, go-fast goodies ,and 3" exhaust w/Super 40, SCT Tuner, 4" hybrid lift, 33" Claw TTC Radials
Eldoradoman is offline
post #3 of 20 Old 12-27-2008, 05:28 PM Thread Starter
abswa
Thx for the link. I just saw something in your signature: LED dash lights?
abswa is offline
post #4 of 20 Old 12-27-2008, 06:12 PM
Eldoradoman
Ya, blue LEDs for my intrument cluster, looks great. Same as these: Item # 200292553893 eBay
post #5 of 20 Old 12-27-2008, 09:42 PM
Kolak
Vendor
Kolak's Avatar
I had that Flex-A-Lite fan on my 1993 ZJ V8 and it didn't cool properly on hot summer days. The shroud does not cover all of the radiator core is the reason. I ended up sliding it all the way to the passenger side of the radiator core and mounting a 12" pusher fan behind the grille in front of the driver's side of the radiator. Cooled fine after that but the 5.9 fan setup still works quite a bit better.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is online now
post #6 of 20 Old 12-28-2008, 01:54 PM
Eldoradoman
Yeah I tried to find a 5.9 fan assembly but had no luck at the junkyards or online. For the price, the Flex-a-lite is perfect for my needs.
Where are good places online to find a 5.9 fan BTW?
post #7 of 20 Old 12-28-2008, 02:00 PM
jeepinjoe123
1994 ZJ
in a like 90-95 ford taurus is the easiest place look up the taurus fan they use the same motor and the shroud fits almost perfect i put one in my trucks with the proper continous duty relays and the fan for under $100 and just have them set-up for switched power haven't forgotten yet and it's been about a year....
1994 JGC limited 5.2l 4in F>R swap 31in. dune grapplers, soft 8's, flowmaster 40 series and duals out the sides, taurus e-fan, high flow intake, 231 swap, 44a swap, NGK plugs, Shell 93 octane only, homemade choppped and drilled light bar, gold>black stripes, in the process of making true cowl induction hood and putting 96-98 cladding, bumper cover, and grill on
jeepinjoe123 is offline
post #8 of 20 Old 12-28-2008, 02:14 PM
Kolak
Vendor
Kolak's Avatar
If you need a brand new genuine Mopar factory assembly, I offer JeepForum members a 25% discount off dealership prices. That's an expensive part though - Mopar more than doubled the list price about a year ago.
or
Kolak is online now
post #9 of 20 Old 12-28-2008, 02:16 PM
Eldoradoman
I've already looked into the Taurus fan swap before I got my Flex-a-lite. The 5.9 fan would be the best option if found for a good price.
The reason I didn't do the Taurus fan swap is because of the extra wiring involved and the much extra current they draw compared to the Flex-a-lite (of course they cool better as a result).
post #10 of 20 Old 12-29-2009, 03:36 AM
86rokee
1989 XJ Cherokee
today my fan whent nuts and shreaded my radiator.so i gotta find a raditator and a fan...
i know all about taurus fans, and i have a 5.0 mustang. the taurus fan draws a buttload of juice at start up, its probably one of the worse fans to use for voltage spikes. us mustang guys have been using and running the taurus fans for years since they do flow alot of cfms but theres a better dual fan out now. FORD CONTOUR ONE PEICE DUAL FAN, low profile and has tabs that. its not well documented as far as how much it flows but it flows plenty and its better than any cheesy ebay fans and will look stock. i have one in my stang with a $20 controller from autozone, no need to hook to the a/c
and the reason for the connection to the a/c is when you have a/c on a normal e fan car the fan kicks on to help cool the motor since the a/c compressor puts a load on the motor.
the contour fan is from a 97ish. theres 2 kinds one is a 2 peice and ones on a sold peice. i know guys run em in wranglers but im not sure how well they will fit the zj. ill have to measure the one on my stang tomorrow. i just hate installing another crap azz clutch fan.this jeep had a brand new 6 month old radiator from the previous owner after the jeep got hit. he didnt put it in quite right, first the tranny line popped off last month then this
heres some pics of the contour fan on my stang. the radiators are about the same general shape. not like the short xj one so i think this might be the best junkyard fan out there. im wanting to do something about the bottom radiator support. i dont like how on the zj the radiator hangs so low and that thin thing barely protects it from getting hit. so i might do some welding while im at it to ad some strength down there. my jeep was hit before i got it and sorta fixed so i have issues to address anyways. i also dont like how the extran trans cooler was all spliced in by the last guy. its some jury rigged crap. heres a link to the torqflo unit im using it has a prob that goes in the upper radiator hose and turns the fan on where you set it. works great and its unde $20AutoZone.com | Relay Kit and Assembly
93 zj laredo 4.0 auto,np 242, on 33x12.50x15 tires
86 xj 2 door 2.5l 4speed stick,np 207,4.10s, 6" of lift on 30s "sold"
86 mustang gt
8 prelude si, 5speed, 4 wheel steer
86rokee is offline
post #11 of 20 Old 01-26-2010, 12:06 AM
ZJ5point2GCL
technically its not the load from the A/C compressor that affects the fan being on or not, its that the condenser in front of the rad needs airflow over it, even if the engine doesn't need cooling. like if you hop in your jeep on a nice 85 degree morning, the engine will be a couple minutes until it needs cooling, but the A/C systems need airflow.
But my question is, how are you controlling the e-fan? is it just on all the time? or on when the water temp gets to a certain point? because i want to put e-fans in my zj, but its a big price difference between a relay and a fan controller
ZJ5point2GCL is offline
post #12 of 20 Old 01-26-2010, 08:01 AM
gamudslinger88
It all comes in the fan controller. Buy a fan controller kit with the biggest relay you can then take the relay and replace it with a larger one. I am about to walk out the door to go get a fan shroud to hack up to hold my Taurus fan. I will try to take pics throghout the process.
gamudslinger88 is offline
post #13 of 20 Old 01-26-2010, 08:07 AM
Area.3.Fiftyone
You can't just pop a larger relay in. Most of the time the wiring in those kits it only rated for the current draw of the relay and you'll end up frying your wiring.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #14 of 20 Old 01-26-2010, 03:43 PM
gamudslinger88
And thats how I like it baby
post #15 of 20 Old 02-09-2010, 12:52 AM
DRUMatthias
I gotta say, while I'd actually prefer to simply buy an in-the-box kit & install it, the fact that nearly everyone goes for the Taurus e-fan, about 6" bigger in diameter than the Flexalite makes it a bit tough to swallow that this could work long-term. While the CFMs would clearly be less, I'm a bit amazed that you run this with a 5.9, when the 12" kit's designed specifically for the 4.0 I6...do you use a larger-diameter Flexalite than I've found online? Not sure they make one but figured I'd ask.
The part of this upgrade that keeps me from going through with it tomorrow is the wiring situation. I've never ran anything but speaker wire in a car so that part of it steers me away more than anything...
What's the consensus? Buy the Taurus fan at a junk yard (or a new one with a wiring kit on eBay or some auto site) along with the Napa relays & wires & whatever else...or buy some other after-market fan option. Is there another brand out there besides Flexalite? Also, how much larger is the 5.9 e-fan that came on the '98 Ltd's (or maybe even some Dakotas)? Thanks for the feedback.
DRUMatthias is offline
WJ Limited All Electric Fan Conversion shashank ZJ Grand Cherokee Forum 8 01-22-2011 09:24 PM
Conversion to Electric Seats daphne ZJ Grand Cherokee Forum 5 09-24-2009 07:45 AM
Question on electric fan conversion OnlyJeep4me ZJ Grand Cherokee Forum 4 02-06-2008 09:02 PM
96 ZJ mechanical to electric fan conversion ta2oodfreak ZJ Grand Cherokee Forum 9 08-07-2007 07:47 PM
Electric fan conversion csh1975 ZJ Grand Cherokee Forum 9 08-09-2004 09:51 PM
