Old Man Emu Lift Questions - Page 2 - JeepForum.com
post #16 of 26 Old 09-13-2010, 03:13 PM
dcullum
I run the OME's HD's w/2" spacers on my 5.9...run the Pro-comps (265's) and I had to trim the fenders a small amount. I just installed adjustable control arms all around and fender trimming is not needed anymore....
dcullum is offline
post #17 of 26 Old 09-13-2010, 06:05 PM Thread Starter
jsc7002
1966 CJ5
Did you have any issues with the OME and spacer? is that all you did and new shocks? Do you have some pics of it?
jsc7002 is offline
post #18 of 26 Old 09-14-2010, 12:14 PM
dcullum
Ome
The spacer worked fine w/the springs. My profile has a picture of the jeep. It had minor fender rubbing (265 Pro Comps) on the front of each fender until I installed the adj track bars.
dcullum is offline
post #19 of 26 Old 09-16-2010, 09:30 AM Thread Starter
jsc7002
1966 CJ5
Does anyone know the spring rate of the stock front coils?
jsc7002 is offline
post #20 of 26 Old 09-01-2013, 06:40 AM
Mark-318-IT
hi guys i was looking for some info on the ome lift kit and got this topic.
may someone tell me the difference between this 2 kits:
http://www.4wd.com/Jeep-Lift-Kits-Je...3&t_pn=ARB9397
http://www.4wd.com/Jeep-Lift-Kits-Je...ARBOMEZJ8CYLHK
why one is 2.5 and the other is 2? are there some different coils?
thanks
Mark-318-IT is offline
post #21 of 26 Old 09-01-2013, 02:49 PM
Kolak
Vendor
Kolak's Avatar
You have a V8 so you will want the HD springs. Typically these springs net 2.5" of lift.
I prefer Bilstein 5100 series shocks to go with them as they give the best possible handling, ride control, fade resistance and responsiveness.
Send me a PM here on the forum or email me at kolak@aol.com if you'd like to chat. I've been an OME and Bilstein dealer for many years.
thanks
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is online now
post #22 of 26 Old 09-02-2013, 01:59 PM
Mark-318-IT
hi, thanks for the infos...i did not understand the difference between the 2 links
btw i got a couple more questions:
1)do i need longer brake lines?
2)do i need longer disconnects?
i'll send you a mail for sure.
post #23 of 26 Old 09-02-2013, 03:52 PM
kg6mov
Hears the voices
kg6mov's Avatar
You won't need brakelines. Longer Sway bar links up front aren't necessary, but discos offroad are a good idea. The JKS discos for stock should be the same parts as for 2.5", they're adjustable.
kg6mov is online now
post #24 of 26 Old 09-02-2013, 04:01 PM
Mark-318-IT
hi, thanks for the infos...so i do not need longer brake lines even when the discos are acutally disconnected, i mean while i'm wheeling right?
post #25 of 26 Old 09-02-2013, 04:31 PM
kg6mov
Hears the voices
kg6mov's Avatar
I haven't had a problem with brake line length discoed offroad.
post #26 of 26 Old 09-03-2013, 01:49 AM
Mark-318-IT
ok thanks
lift , old man emu , ome , zj
2" Lift Questions.... Wheels and Tires Questions Too!!! torchd ZJ Grand Cherokee Forum 13 01-22-2010 03:35 PM
ZJ -5.2- Lift Questions vdub ZJ Grand Cherokee Forum 7 12-07-2009 09:30 PM
Lift questions limited_pit ZJ Grand Cherokee Forum 2 02-17-2009 06:54 PM
lift questions? 95gcg ZJ Grand Cherokee Forum 2 12-23-2007 03:10 PM
More Lift Questions ryanp ZJ Grand Cherokee Forum 6 10-06-2006 10:43 PM
