Old Man Emu +2" - Page 2 - JeepForum.com
post #16 of 24 Old 10-01-2009, 02:51 AM
CMARJEEP
CMARJEEP's Avatar
Originally Posted by WXman View Post
I disagree. If a tire is low on one corner, it's going to cause the suspension to be offset on the opposite side, and especially the opposite corner. That's why a vehicle with a flat tire sags and sits all awkward if you look at it from behind. 0 psi somewhere is going to give you much different readings hub to fender than all tires at 40 psi or whatever.
Are you just trying to argue for the hell of it? Nobody is going to measure their lift height with one flat tire and the rest inflated. It is the best and most accurate way to measure lift height.
CMARJEEP is offline
post #17 of 24 Old 10-01-2009, 05:52 AM
WXman
Nope, I'm not. Just trying to stop the misinformation that goes around in these forums. Measuring from the center of the hub is only as accurate as the level ground the Jeep rests on...therefore saying it's the only accurate way to do it is WRONG. I'm just tired of hearing it.
In any case, back on topic... I agree the medium duty springs will cause it to sit a little higher in the rear. So I think his condition is normal.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #18 of 24 Old 10-01-2009, 06:03 AM
Area.3.Fiftyone
It is not wrong.
Measuring from the center of the hub is the correct way "IF" you are sitting on level ground. Obviously if one of your tires is: in a ditch, up on a rock or a ramp the reading will be different because of axle flex.
This takes tires size and inflation out of the equation.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #19 of 24 Old 10-01-2009, 06:31 AM Thread Starter
JMOSS
From the hub it's a good idea, but from the ground is the same too, obivusly you have to do it properly:
levelled ground, tires with same pressure.....
Anyway, back to the topic: I know rear is higher with medium duty springs, the point is if that much is ok or not ok.
Normally with stoke is about 0.4, up country ones 0.4, ironman the same....i dont'have data on others brands.
1.2......it seems too be too much.
Do you know someone in the forum who has a wj with Old Man Emu Springs?
Just to compare......
Any sellers who can help me? Kolak come on, give me your opinon!
99 WJ 4.7V8 Limited QTII , LPG system, 180 Tstat, Magnaflow cat, Up country coil springs, Procomp MX6 shocks absorber, ADDCO swaybars & gresonable bushings, General Grabber AT2 tires, Usa spec pa-chr11 Ipod interface.
JMOSS is offline
post #20 of 24 Old 10-01-2009, 06:44 AM
Area.3.Fiftyone
It's all your personal preference.
Having the rear slightly higher when unloaded is not a bad thing. When you put some weight in it, it will settle.
I personally like my rig to sit level unloaded or with a slight rake Rear to Front.
post #21 of 24 Old 10-01-2009, 06:52 AM Thread Starter
JMOSS
Slifgtly ok, 1.2" not seems slightly too me ....My fear is it can compromise genaral stability.
Right know i have loaded some staff too lose about 0.5 inch....and it run (handling ecc) much better.
Sometimes new springs can have problems and the company can change them....but i dont' want to boder them if not sure that it's a problem or not, or just a temporary problem.
JMOSS is offline
post #22 of 24 Old 10-12-2009, 08:49 AM Thread Starter
JMOSS
any helps?
JMOSS is offline
post #23 of 24 Old 10-12-2009, 09:19 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Give them more time.
My ZJ HD OME coils have sagged over an inch since new. The OME coils aren't all they're cracked up to be.
HighLonesome is offline
post #24 of 24 Old 10-12-2009, 09:22 AM Thread Starter
JMOSS
I hope so in this case!
tx
JMOSS is offline
"xenon" or "true white" headlight bulbs .. exist? sanboy ZJ Grand Cherokee Forum 16 10-12-2010 09:23 PM
Front Calipers "Teves" or "Akebono"? jimmy328 ZJ Grand Cherokee Forum 10 07-25-2009 09:48 PM
"Grand Cherokee" and "Limited" emblems? jdwiseman ZJ Grand Cherokee Forum 14 02-04-2009 06:49 PM
burning "smell" issue and "gas pedal vibration" issue in 07 gc laredo beepbeep13 WK Grand Cherokee & XK Commander Forum 4 01-08-2007 06:06 PM
Chirping/Squeaking only when in "Park" or "N" 3D-Dave ZJ Grand Cherokee Forum 1 05-01-2004 03:05 PM
