OKAY, a real 42RE issue for the REAL fanatics! - JeepForum.com
post #1 of 8 Old 01-22-2012, 08:56 PM Thread Starter
PhillyBluntz
I have a 95 JGC Laredo with a 4.0 and the 42RE. I have been experiencing some issues with the tranny that have not been posted as far as I've read on several sites.... The trans used to shift fine, after adjusting the throttle cable. Pulled up to a stop and wait just a second, go to take off and first is there. after about a month after adjusting the throttle-trans cable, she starts not wanting to shift down to first so much (especially if she's cold). If this happens, I throw her down to first, take off, go right to OD and everything is good. That was the case for about a week or two, and a couple nights ago, went to the next town over and discovered that even throwing it down in first wouldn't get her to go. seemed like she wanted to start in second... now (another week later) she wants to start in 3'rd... but I HAVE OD, and the TQ will lock telling me (as I have read) that it's not totally in LIMP MODE.... I've ordered the whole kit off transource or whatever and am planning on replacing all the internal sensors/senders, but I could really use some expert advice on this one. I have been mechanic'in since I was 8 and I know my **** when it comes to cars, but this one is different from every other post I've read so far. The only codes on the TX OD light are 24 and 26 (and of coarse the 55) so I figured it had to so with the pressure switch, so I said to hell with it and ordered the whole kit. Not sure what the deal is with the OD light output thing is, cuz the light works when I hit the brakes, but ???
ANY help would be GREATLY APPRECIATED!!!!!!
Thanks in Advance! Phil
PhillyBluntz is offline
post #2 of 8 Old 01-22-2012, 09:35 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
If it will not even downshift in manual 1, you have problems with the band apply servo, low/reverse band, or valve body.
ratmonkey is offline
post #3 of 8 Old 01-23-2012, 09:05 AM Thread Starter
PhillyBluntz
Thanks for the quick reply! Wanted to update.... I was driving home last night and found that if I put it in neutral at lights and went right from N to 1, first would engage 90% of the time, no slipping or funny noises, but as soon as I allowed it to shift out of first, I'd have to do the N to 1 while stopped again to get it to engage first. Just pulling down to 1 from D would engage second, but not first. Now I'm baffeled.
PS This trans has been running Dextron 3 since I bought it and I am wondering if I need to have it power flushed and ATF4 put in?
and Reverse engages Strong, no slipping
post #4 of 8 Old 01-23-2012, 10:56 AM
PolkaPower
I was under the impression that atf 4 is what should be in the 42re. Dex for the aw4. I wouldn't power flush it you may end up with much worse problems. Just drain and refill. atf-4 is what should be in there.
PolkaPower is online now
post #5 of 8 Old 01-23-2012, 11:03 AM Thread Starter
PhillyBluntz
Absolutely correct! I was under the impression that my trans was an AW4 when I bought it so Dex3 was what I put in. Do you think that just draining and refilling with ATF+4 will help? I was thinking it would be best to get all that Dex3 out and a flush is really the only way I know of to do that.....
post #6 of 8 Old 01-23-2012, 11:17 AM
PolkaPower
I think it could make a big difference. atf-4 is much more slippery and holds up to sheering much longer. I would just drain it as much as you can. Let it drain overnight then fill it to operating level. I would repeat this a couple of times if you get positive results the first time. There is a way to get all the fluid out if you pull the transmission return line(I think) from the RAD and it will pump out while it is running in neutral. You want to pour fresh fluid in at the same time until you see the new fluid come out of the line then hook it back up and top it off. You have to be careful not to over fill it or get any air in the system though. I would go with just drop the pan and refill. It's easier and cheaper. If that works well then do it again soon after.
post #7 of 8 Old 01-23-2012, 11:19 AM
edpmedic
Did the Trans start to shift like that after a Trans fluid change or after the throttle cable was adjusted? Also is there a difference the way the TV is supposed to be adjusted on a AW-4 compared to a 42re adjustment.
Never4get those who gave their lives on 09-11-01 WTC and Pentagon. FDNY-EMS-NYPD-PAPD. Also those who are still dying.
_______________________________________________
"Freedom is never voluntarily given by the oppressor; it must be demanded by the oppressed."
Martin Luther King, Jr.
"Always aim at complete harmony of thought and word and deed. Always aim at purifying your thoughts and everything will be well."
Mahatma Gandhi
Feel the Sunshine on your face
edpmedic is offline
post #8 of 8 Old 01-30-2012, 09:45 PM Thread Starter
PhillyBluntz
Figured it out guys, I replaced the solenoids and transducer, even did a short vid of it, but am not able to post it yet I guess. She's running GREAT!!! Oh, and the accumulator spring was broken in three pieces! Thank God it came in the kit I bought!!! Oh, and the magnet in the bottom of the pan was SHATTERED!!! I found an old hard drive layin around, stripped it down and used the magnets from it after cleaning all the chunks out I could find.
42re
real LOW volts wickerham ZJ Grand Cherokee Forum 13 12-18-2010 02:10 PM
WK real world MPG Reswob WK Grand Cherokee & XK Commander Forum 25 12-20-2007 06:30 PM
REAL tech Arkansas_WJ ZJ Grand Cherokee Forum 11 03-27-2007 10:22 AM
Is this for real? Test ZJ Grand Cherokee Forum 3 05-17-2006 09:17 PM
Will the real VIN please stand up rickd. ZJ Grand Cherokee Forum 7 02-06-2006 11:06 AM
