Okay - The Issues on my "New" ZJ - JeepForum.com
post #1 of 11 Old 08-08-2012, 12:56 PM Thread Starter
PAFirefighter11
Quadratec Live Chat Rep
PAFirefighter11's Avatar
2015 JK Wrangler
So this was my last ZJ:
I just picked up a new one last night for $1000. It's a '96 ZJ Limited, 4.0L, auto, NP249 (blah), 99,990 miles, leather, new tires, etc:
I'm not a mechanic, though do 90% of the work on my Jeeps myself, and/or with the help of friends who are mechanics. There are a few mechanical issues which I am not worried about and will fix quickly. A few others I have questions about. The questions are...
-The oil pressure when I started the Jeep last night was at 0. Check gauges light came on. I checked the oil. Level is fine, oil color is great. After physically hitting the gas/driving, the pressure went up to normal operating range. Each time I would let off the gas/stop, the gauge would drop back to 0. I'm assuming this is just the sending unit going bad as they tend to do on a lot of 4.0L applications?
-The steering SUCKS. It's very loose and tracks where it wants, which has to be corrected very often while driving. It's like driving my Trans Am's with large front tires, but it's not "tight" steering. Fairly unresponsive - absolutely nothing like my last ZJ. My assumptions are the steering gear box, hubs, or an alignment. Is that correct?
Any help is much appreciated.
-Rick R
-2015 JKU - 3.5" JKS JSPEC Kontrol, 315/70R17" MTZ's, 17x9" Quadratec Rubicon Xtreme's, JCR bumpers & skids, JW Speaker tails, Dirty Dog netting/screens, Quadratec Auto Mirror Movers, etc
-03 VW Golf TDI - Diesel
-FDNY 9/11/01 - All gave some. Some gave all.
PAFirefighter11 is offline
post #2 of 11 Old 08-08-2012, 01:47 PM
JohnnyZJ
no oil pressure = bad. you can physically test it with a guage, but its easier to replace the sensor for now and see if a new one reads correctly.
your steering can be a few things. gonna have to get under and check. have wife wiggle the wheel back and forth. watch the track bar and see if it moves. any movement = bad. watch both the axle end and frame end.
steering box could be an issue too. if it is, you can tighten the box with the little allen key thing on the top of the steering box. just a little bit though liek 1/4" of a turn. this is a last ditch resort; the box is likely pooched.
also, check for loose tierod ends as well. do this while wifey is doing the 'wiggle' test with the steering wheel.
to test for hubs/balljoints, jack one wheel up at a time and give the wheel a shake with hands at 3 and 9 oclock on teh wheel. there should be no play or 'clunks' if there is, somethings loose.
07' JKUR rollin on 35s
JohnnyZJ is offline
post #3 of 11 Old 08-08-2012, 04:45 PM
ZJMTL
Try a new sending unit. I got one at the JY for 3$
ZJMTL is offline
post #4 of 11 Old 08-08-2012, 05:39 PM
Dark_Sorrow
1994 ZJ
I've gone thru two oil pressure senders in 3 years.... and they are only like 40 bucks new. And steering could be a many of things as you know
Dark_Sorrow is offline
post #5 of 11 Old 08-08-2012, 06:21 PM
veritechc
I had to replace the steering box on my 95 ZJ 5.2 8 cylinder. It was $120 from Autozone and took a couple of hours to put in. You REALLY need to get a handel on the no oil pressure. That will kill a jeep quick.
veritechc is offline
post #6 of 11 Old 08-08-2012, 07:35 PM Thread Starter
PAFirefighter11
2015 JK Wrangler
It definitely has oil pressure. I've driven it a few hundred miles so far and the engine temp is normal, there is no knocking or ticking or anything, so the oil pump is obviously working. I'll grab either a new sending unit from work or something at a yard.
For the steering, I had two of my buddies look at it. Both confirmed it's the steering box that's loose/bad. I'll grab one at a yard as well.
Thanks guys.
-Rick R
post #7 of 11 Old 08-28-2012, 07:20 AM Thread Starter
PAFirefighter11
2015 JK Wrangler
Adding to this: The last 5 times I've started the Jeep, hit the gas, and go it loses power (Kindo of bucks around) and makes some popping noises (nothing like an exhaust backfire - it's not super loud). After about 3-10 seconds of this is done and does not happen again.
Also, while on the highway it feels like it's lacking power. To keep up with traffic, especially on a slight to moderate incline, I need to full stomp the accelerator to get it to kick down into another gear and get moving. This is my first NP249 vehicle, so I'm not sure if that's just how it is with this t-case setup or not.
-Rick R
post #8 of 11 Old 08-28-2012, 12:07 PM
Scopez
1994 ZJ
Is the TV cable properly adjusted? My ZJ, V8 NP249, kicks down fairly quick when climbing an incline at highway speeds. Check your tcase fluid also.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #9 of 11 Old 08-28-2012, 12:34 PM
newfieZJ
You need a complete inspection done on the steering , track bar and CA bushings for starters .
Your first issue above sounds like the upstream 02 sensor . Unplug it , you will get a CEL but the bucking and popping should no longer be present .
Second issue above sounds like a bad cat , could be the 02 sensor also . It's not the 249 .
newfieZJ is offline
post #10 of 11 Old 08-28-2012, 07:38 PM
timmay5309
Adding to this: The last 5 times I've started the Jeep, hit the gas, and go it loses power (Kindo of bucks around) and makes some popping noises (nothing like an exhaust backfire - it's not super loud). After about 3-10 seconds of this is done and does not happen again..
I had the exact same problem that was the upstream O2 sensor needing replaced. Remember, Mopar or NTK sensors only
timmay5309 is offline
post #11 of 11 Old 08-29-2012, 11:22 AM Thread Starter
PAFirefighter11
2015 JK Wrangler
Thanks guys. The steering issue is definitely the box. Serious play in it. I can still drive it, but it's not fun. I'll have a new one in there soon.
As far as the stumbling goes, I'll check the cat and o2's this weekend. I appreciate the suggestion.
-Rick R
issues , problems , zj mechanical
"POP" sound issue when turning, maybe related to alignment issues? pdxjeep ZJ Grand Cherokee Forum 18 09-10-2011 01:18 PM
Help with "new" '06 Jeep? Possible issues? Suggestions? myasylum WK Grand Cherokee & XK Commander Forum 1 07-28-2011 11:56 PM
1995 Laredo Weird "bucking" issues while driving jrsquared ZJ Grand Cherokee Forum 3 07-12-2011 07:20 AM
99 GC Limited "issues" with front end jitterthebug ZJ Grand Cherokee Forum 4 07-09-2009 03:42 AM
issues with the lift,.."rubbing" coyote runner WK Grand Cherokee & XK Commander Forum 6 10-24-2007 06:28 PM
