07-23-2009, 05:21 PM
#1
Ok I Have Good And Terrible Please Help!!
so the good is my iron rock off-road lift came today :-)
now the bad i think i need a front diff :-(
out of no where my jeep doesn't like sharp turns (just like if you stuck in 4wheel but i know it isn't) doesn't hop but its deff not good
i started with changing my diff fliud(using lmt slip add bc i have a dana) then i checked universals and wheel bearings they are all good
it seems like i have too much back lash in the front pinion but nothing looked torn up when i did the service yesterday
are there any adjustments shims or anything or am i in need of a diff rebuild??
07-23-2009, 05:37 PM
#2
Living dead mod
1st, what jeep do you have.
2nd, what transfer case do you have.
#3
it would def help if we knew what platform you had, but if its a quadradrive sounds like someone needs a new VC
edit: Damn ratmonkey beat me to it.
2010 JK 4-Door Unlimited Sport- Soft top, V6, 6-speed standard, bone stock for now
07-23-2009, 05:49 PM
#4
i have a select-trac 98 grand with a straight six and danas front and rear stock height and tire size at the moment let me know if theres anything else you need to know
07-24-2009, 04:10 PM
#5
turns out i had play in the spiders in between the pin and gears so i need to replace my spiders
07-24-2009, 05:54 PM
#6
You only need to add limited slip additive if you have an LS, not because its a Dana.
95' Jeep Grand Cherokee Laredo, 148k, 5.2, NP242, 46RH, 4" RC lift, all new adjustable ca's(2 IRO front uppers and the rest RC adjustables), nitro shocks, JKS TB's, Jet Chip, Dynamax cat back, Magnaflow cat, GTP hood vents. 31" Pro Comps with Rock Krawler "D"s. Westin brush/grill guard with Hella 500s, 411's, Solid diff covers, detroit locker rear, power lock in front, SYE and Tom Wood's front/rear shafts, RE discos, BPE's, d-rings front and back, factory tc and rad skid, hitch, Sliders next.
03' Jeep Grand Cherokee Laredo, (wifes Jeep) 99k, 4.7 5 speed auto, K&N, KYB shocks, drilled-slotted rotors, All the toys.
2000' Ford Superduty, F250, 7.3, 198K, 37's, too much to list.
Built Not Bought #257
Parts for sale d30 and d35 parts http://www.jeepforum.com/forum/f126/...-parts-1004499
07-24-2009, 08:35 PM
#7
thank you guy but i know that i have ls and i have bad spiders
07-25-2009, 02:39 AM
#8
what kind of axle do you have in the front? if its all stock it makes me agree with the guy saying you don't have a locker in the front. if so what kind do you have?
96 zj. 31x10.50 uniroyal awts. 2.25 bb rough country 9000 shocks. rustys transmission crossmember
cobra radar detector future mods:rustys 5.5 long arm kit and smittybilt xrc8
07-25-2009, 11:12 AM
#9
Actually i was refering to this statement you made, which made no logical sense.
You might have one in the back. Filling out your profile might help too.
07-25-2009, 11:50 AM
#10
Mr. Hyde!
The only way spiders would be bad is if they had chunks out of the gears. Very noticeable.
07-25-2009, 11:51 AM
#11
Mr. Hyde!
Such as these spiders I pulled out of my front diff...I had no symptoms though. It wasn't until I opened up the diff to do a gear install that I noticed something was amiss
07-25-2009, 03:25 PM
#12
Maybe I'm missing something, but limited slip and spider gears are mutually exclusive as far as I know. Either you have spider gears, which is an open diff, or you have a limited slip clutch pack in the carrier where the spider gears would go.
07-25-2009, 03:38 PM
#13
if this is a stock set-up you shouldn't have LS in either axle. LS was an option for the v8 models. i dont know of any 6bangers that have ls but i suppose it is possible. however jeep did NOT put ls in the FRONT axle, only in the rear as part of the factory towing package. all GC have dana axles front and rear most being the dana 30 in the front.
07-26-2009, 09:23 PM
#14
yea i believe i made a boo boo no limited slip up front and if i drive my jeep anymore my spiders will look like that guys
07-27-2009, 08:01 AM
#15
Mr. Hyde!
If your spiders don't look like that now, why do you think they will be?
