#1 | |
Ok, this has got to stop
Ok, over the weekend I installed some upcountry springs, a pain because I hate spring compressors more then the dentist and paying taxes combined, so I disconnected the shocks and the sway bar to get more drop.
On the passenger side rear, whenever I go over a bump or hit a small pothole, there is a semi loud "cha clunk" sound. It is annoying as hell. I did the same procedure on all 4 wheels and its the only one doing it. Everything is tight (68ft lbs) spring is secured. Car seems to handle exactly the same... Any ideas? They are bilstein 5100 shocks in the rear from kevins 2.5kit, and yes I have had teh shock sleeve mounting kit on for months with no problems.
[url=http://www.mazdaworld.net/forums/index.php?showtopic=19]"Within the mind lies the greatest of all evils...Eternity" - Enigma02S[/url] [url=http://www.cardomain.com/ride/2370949]2000 Millenia S...Five figure spending account[/url] [url=http://www.cardomain.com/ride/2384051]1998 Jeep Grand Cherokee...Gone but never forgotton[/url] [url=http://www.cardomain.com/ride/2383985]2003 BMW M3 SMG...For Sale, PM if interested[/url] [url=http://www.cardomain.com/ride/2484240]2000 "Jeep Grand Cherokee...4.7, Quadra-Drive, Loaded.[/url] "A dark and bitter chill fills the air. once thriving life wallows away into ash as he slithers past, the very stars themselfs part to make way for his haunting, yet oddly claim arrival. Bhr approaches." - Hatter "But i have to say, BHR's rants go hand in hand with moring coffee to get my day started - RXL" Admin - [url]http://www.mazdaworld.net[/url] |
#2 |
try swapping the rear shocks side to side and see if the noise moves
Steve Wright 1999 4litre WG Limited, 3.5" OME lift, IRO adjustable front arms, IRO adjustable rear a-arm, IRO adjustable RHD trackbar, 3.91 Diesel Quadradrive axles, 235-85-16 Grabber AT2's Build thread 2001 4litre WG Limited, stock apart from 245-75-16 Grabber AT2s, the wife's Jeep 1990 4litre MJ, work in progress Build thread steve@offroading.net www.offroading.net |
#3 |
i would look to make sure that nothing would hit on compression or extention like the sway bar endlinks.
Greg
98 zj (The Vixen) 5.2 V8, 4 in f>r, 31's, Built not Bought member #247 SOLD:( new DD- 04 polaris sportsman |
#4 | |
Just a suggestion...
Now what did I ever do to you? ![]()
'04 4.7 WJ 6" Clayton's, 60\14b, blah blah blah |
#5 |
I_R_Food
check to see that the springs sit in the same "grooves" the old ones did
might just not be seated correctly
1995 YJ gone as well 2001 Grand RIP
2004 Rubicon RIP |
#6 | |
haha. I love the dentist. I just fall asleep and when I wake up my mouth feels great. wow.... that sounded really friggin gay. |
#7 | |
Addicted to Boost.
HAHA I was waiting for that. BHR do you have disco's?
2007 VW GTI |
#8 |
No disco, as for the springs, the end might be slightly off from where it was, but its no different then anywhere eles on the car. The thing is when I first got my lift kit I didn't bother with the rear shock sleeve mounting thing, and it made this exact same sound from both rears, got it, put it on, and it was fine for almost 3 months until I did this.
#9 |
Yea, I'd check to make sure nothing hits during compression and expansion. My swaybar endlinks hit my rear coils ever so slightly.
#10 |
I still have no idea what it is but seems to be getting slightly better the more I drive, now it only does it on bigger bumps. Probably going to spend my holiday weekend searching for dodo bird in the ocean
#11 |
I would give it some time to settle...my whole setup is a ton quiter now than when I installed it...
Even though I get to go through it all again ![]()
Nickerdoodle 03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's 35" BFGoodrich KM2 sira4x4.net North East Offroad Club www.carolinadriveline.com www.ironrockoffroad.com kolak@aol.com |
#12 |
I did check, and nothing seems to be hitting at all anywhere. I'm going to try some wd-40, then tighten it up and see how it goes, but its driving me freakin crazy...and now this gear/tire whine type noise that sounds like it could be the diff bothers me, even though all I did was put on these springs
#13 |
kind of off subject but did you add front trac bar? Your fo sho over 3"
Mitch 2000 WJ Limited - 4.7l, 4x4, pioneer HU w/ ipod interface, upgraded front calipers, yakima lowrider system, uniden cb w/ 4 ft firestick, 3.5" tweeter upgrade |
#14 | |
So far I suspect a problem with the spring, or spring isolator, or the rear axle bearing. I'm really hoping for the first Any ideas? |
#15 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
