#16 | |
GettinStuck,
I wouldn't use that mechanic. ![]() - Brian
For some reason, being a member of the CharGold Jeep Club just isn't as cool... Member #1 |
#17 |
Anyone know if you can just pull the two elbows off? I tried, and it seems like I'm going to break something they are so tight.
1994 Jeep Cherokee Laredo I6 |
#18 |
you can pull of the elbows - the front one is the same size diameter as the outside the rear one has a pinhole sized hole at the connection to the valve cover - when this pin hole gets clogged the vacum from your air filter starts to pull oil from the valve cover rather than the rear one evening the pressure between the valve cover and intake manifold - I had the same problem with my 95 ZJ 4.0L - just popped the rear elbow off - cleaned it out and replaced the rubber grommet and plastic hose connection (it desintigrated on me) and it solved the problem.
#19 |
The elbows may also break when you try to take them out. They press pretty tightly into the grommets and they will become brittle over time. I was unable to take mine out without breaking them.
Here's the Catch 22 that I ran into: I wanted to remove the valve cover before I tried to remove the elbows, so that if they broke, plastic wouldn't get into the valve train. Except the proximity of the rear elbow to the cowl didn't allow me to lift the valve cover over the rockers far enough to get the valve cover off. HTH - Brian
#20 | |
Now that's funny Stop using your brain and get a hammer man! You smash that freakin thing then remove the valve cover and spend the rest of the afternoon cleaning all of the bits out!!!
Cheers Steve Trained Professional Crack-pot Go RU & WVU Football Teams 94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new 03 4Runner V8 (my wife's car) 94 Volvo 850 (my 16-yr old daughter's car) Five cylinder 88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new |
#21 |
So does anyone have the correct part #'s for a ZJ or is this thread dead?
#22 |
Retired back to Bowties
Go to a dealer, they can look it up. This thread has now been reincarnated twice.
Woody 1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch. |
#23 |
Because it is an awesome thread!
1995 YJ, 2.5L, RE 4" lift, 0" Body lift, JB SYE, Woody shaft, FoMoCo e-Fan, 4.0 TB, 19lb Ford Style 3 Injectors, American Racing Bajas, 33" Toyo A/Ts /l , [____], l---L--[]lllllll[]- ()_) ()_)==@=)_) |
#24 |
Yup..thanks for this thread. my rear tube broke off at the valve cover this weekend when I attempted to clean it.
For a 1993 ZJ, as of Nov 2006, the front tube is $12 and the rear tube is $16 from my local dealer. I am picking them up today. |
#25 |
That’s because every 4L engine on a ZJ, will dump oil on top of the air filter at some point in time. Same thing with the oil pressure sender. It’s garbage and will leak. Both the CCV valve and the oil pressure transducer should be on the 100,000 mile maintenance schedule. (as a replacement part)
#26 | |
Also on the list: rear main seal rear wheel bearings getting the play out of the steering |
#27 | |
Was going to send you a link to this site, knowing how busy you are work, and the limited time you have to surf the net. See ya tonight, we'll get some of your issues sorted out. Wonder if there any "Anarchists" on this board, Hike *****es!
Equal Oportunity Jeep Owner 85 CJ-7 86 Grand Wagoneer 94 Cherokee 04 G-Cherokee |
#28 |
CJtoWJ:
It figures you'd hunt me down on some other forum where we have stuff in common...are you stalking me???? Thanks for your help. I have beer in the fridge I picked up those parts today..I'll get an air filter also on the way home. This forum (and its members!) has saved me many times with regards to this vehicle ![]() How'd you get the JeepForum Supporter thingie? I paid my $25 months ago ![]() |
#29 | |
Agree, the folks on this site know their Jeeps, most have "been there, done that, have the t-shirts and coffee mugs". I had the "Jeep Forum Supporter Thingie" applied shortly after making the payment. Perhaps you made the wrong person $25 richer...
#30 |
Jeep Jedi Master
Will you guys stop digging up old threads! Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns and 33 Bridgestone Duelers Detroit and true trac Red Jeep Club Member REDNECK JCM Texas Jeep Owner #6 USN Jeep Club #4 http://www.kevinsoffroad.com/ 602.841.3355 For your performance needs: kolak@kolakperformance.com 480.998.3661 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
