Oil weight for 4.0L? - JeepForum.com
post #1 of 9 Old 01-22-2009, 06:45 AM Thread Starter
jasonodle
What weight of engine oil should I be using in my 04 grand cherokee with the 4.0L?
I have inherited this vehicle through my newish girlfriend, so I am trying to get all the info I can before I dive in. It needs an oil change and a tune up.
Anything special that needs to be done to this model?
Thanks
jasonodle is offline
post #2 of 9 Old 01-22-2009, 06:51 AM
Turbonut is offline
post #3 of 9 Old 01-22-2009, 07:33 AM
trail-rated
Thanks
I see in your profile that you have a V6. That's very rare! LOL
The WJ's either came with an I6 or a V8.
Does it have 4WD? If so, you should also change the transfer-case fluid, changing diff fluid is also recommended. The 4.0 is a flat tappet engine so it needs allot of zinc in its oil, look for 10W-30/40 high mileage oil or go with shell rotella T 5W-40 synthetic (my 4.0 loves that oil!).
Hope this help and to the forums!
[ ]IIIIIII[ ] |2001 WJ|4.0L|42re|Quadra-trac II| Too many mods to list|
trail-rated is offline
post #4 of 9 Old 01-22-2009, 08:47 AM
walter_da_jpr
4.0 Piston Skirt Victim
walter_da_jpr's Avatar
I have found 5w-30 to work great. I religiously use Mobil 1 synthetic truck and suv. It starts great even when its -15F out.
WALTER
walter_da_jpr is offline
post #5 of 9 Old 01-22-2009, 09:33 AM
Ridin' Around
Trail rated is correct, you want a high ZDDP oil, which is higher in Zinc, an anti-wear additive that is important for the flat tappet cams. API has reduced the ZDDP levels in newer oil because that same additive causes premature wear to the Catalytic Converters. You need to shop for an oil that retains the ZDDP levels. Alot of people choose to use a diesel type oil, but there are many oils on the market with acceptable ZDDP levels.
Here is a TSB from Amsoil explaining it a little better, if you would like to read about it.
https://www.amsoil.com/dealer/techse...t%20Tappet.pdf
Also get a good filter, WIX is a popular quality filter with a good anti drain-back valve. Stay away from Fram!
Ridin' Around is offline
post #6 of 9 Old 01-22-2009, 09:36 AM
trail-rated
Originally Posted by Ridin' Around View Post
Get a good filter, WIX is a popular quality filter with a good anti drain-back valve. Stay away from Fram!
X2
Fram sucks.
post #7 of 9 Old 01-22-2009, 10:22 AM
MCHJeep
I personally am partial to Rotella T 15-40 diesel oil. It has detergent in it for cleaning and has excellent viscosity. I like to change oil every 2K kilometers and filter (Wix preferred) every 2nd oil change (only if the oil doesn't look that dark). I use the Rotella on all my motorbikes too. Synthetic is also good but I prefer the Rotella T (much cheaper) and more often oil changes.
just my preference.
Two wheels or four wheels, it's only fun.
MCHJeep is offline
post #8 of 9 Old 01-13-2013, 07:47 PM
NewLegs
X3
Friends dont let friends Fram their Jeep.
NewLegs is offline
post #9 of 9 Old 01-14-2013, 09:51 AM
JS97ZJ
I was iterested in reading that info but the link didn't work.
So here is the link that does, for those who want to read it.......
http://www.amsoil.com/techservicesbu...t%20tappet.pdf
JS97ZJ is offline
CRD Oil Weight MacCherokee WK Grand Cherokee & XK Commander Forum 36 09-04-2009 01:25 PM
why WK CRD weight that much? super7668 WK Grand Cherokee & XK Commander Forum 3 10-01-2008 05:40 PM
Weight this weight that... gsxr150 WK Grand Cherokee & XK Commander Forum 5 10-31-2007 07:49 PM
oil weight BLACKzj52 ZJ Grand Cherokee Forum 1 08-13-2007 11:08 AM
Oil Weight D Berk ZJ Grand Cherokee Forum 3 06-23-2004 08:11 PM
