Oil for transfer case - JeepForum.com
post #1 of 14 Old 04-03-2008, 09:57 PM Thread Starter
cherokeeswede
I had the rear differential wheel bearings replaced recently on my 2002 GC.
How would I know if the shop put in the correct oil for the transfer case? As I understand it, the oil has to be Mopar of a special type.
What happens if the wrong oil is used? Vibrations? More wear?
cherokeeswede is offline
post #2 of 14 Old 04-03-2008, 10:10 PM
tennesseewj
Well it depends on what transfer case you have (hint - fill out your profile so people can check). If you have the Selec-trac (242) then it just uses ATF +4; however, if you have Quadra-trac or Quadra-drive (247), then yes you DO need dealer-only fluid. As far as telling the difference, I'm not too sure. Did you try asking the mechanic what he used?
If it is a 247 and the wrong fluid is in there, your progressive coupler won't like it too much, but as long as you don't ride around too long with it you should be okay
2004 4.0 Selec-Trac
BB->Black Diamonds->General Grabbers
Originally Posted by Sporer65 View Post
You need to learn, there are 3 things that all JF members must like beside Jeeps:
(1) Guns (2) Women (3) Bacon
Originally Posted by GraKee99 View Post
I was bored so I forded the river. No oxen were lost.
tennesseewj is offline
post #3 of 14 Old 04-03-2008, 10:11 PM
UUJ1
Please clarify... there are no wheel bearings in the T.C. so they shouldn't have touched the T.C.
If you asked them to change the fluid in the T.C., then ask them what kind they used. And yes, if you have the 247 (Quadra Drive/ Quadra Trac II) then you need 247 T.C. Fluid from the dealer.
If you have the 242 (Selec-Trac) then ATF+4.
'99 4.7 WJ,
3" IRO/Addco rear sway bar/ 31x10.5 Pro Comp XMT's(Yes, I changed my mind and decided on these)/ Pro Comp Mountain Crawler soft 8's 15x7 w/3.75" BS
242 in my garage... still
UUJ1 is offline
post #4 of 14 Old 04-03-2008, 10:16 PM
GibsJeep
Did they work on just your rear diff or your T-case? Or both? Which T-case do you have?
link- http://www.wjjeeps.com/service/maintenance_wj.htm#TCASE
GibsJeep is offline
post #5 of 14 Old 04-04-2008, 07:15 AM Thread Starter
cherokeeswede
They worked on the rear differential. I rememeber now that I also asked them to replace the oil in the transfer case. So I believe they are two separate items. It was a few months back.
I have the 4.7 liter Quadradrive so that would be needing the special oil. I did not do the repair at an authorized dealership, which is why I am wondering.
At the time of the repair I did ask if he knew which oil to use, and he seemed really sure of himself that he did, but now I regret not double checking.
I think I am going to replace the fluid myself today. Are there any Guides for doing this somewhere?
I will update my profile.
post #6 of 14 Old 04-04-2008, 07:21 AM
JG_Canuck
I'd check with the mechanic first to see if they did really use 247 fluid. If not, then change it... You should also inquire if they put the friction modifier in the rear diff when it was re-filled after service.
To change: open fill (top) plug. Put pan under TC. Remove drain (bottom) plug. When it's empty, put the drain plug in, fill it up to the fill hole (Take about 1.75 of the bottles) and put the fill plug in. You're done.
Canadian Jeep Club Member Forty-Two
JG_Canuck is offline
post #7 of 14 Old 04-04-2008, 07:34 AM Thread Starter
cherokeeswede
Thanks!
If I want to replace the oil in the front and rear differentials, are there instructions for this somewhere?
I have had many bad experiences with repair shops lately, I think I will just get all the fluids replaced my self. That way I now it was done right.
post #8 of 14 Old 04-04-2008, 07:52 AM
JG_Canuck
Use the wjjeeps link above to get the specs on the fluids you need.
Diffs are drained by removing the cover. You need to make a new seal using RTV when you re-install. Fill it up to the level of the plug. Quadra-Drive system needs friction modifier in the gear lube for the front and rear diffs.
post #9 of 14 Old 04-04-2008, 07:55 AM Thread Starter
cherokeeswede
What is RTV?
post #10 of 14 Old 04-04-2008, 07:59 AM
JG_Canuck
RTV silicone sealer/gasket former. Just ask for it at your local auto parts store.
post #11 of 14 Old 04-04-2008, 08:52 AM
tennesseewj
Ask and you shall receive
http://www.getahelmet.com/jeeps/maint/diff_fluid/
It's a breeze even if you've never done it before
2004 4.0 Selec-Trac
post #12 of 14 Old 12-05-2008, 10:53 AM
swataz
Resurrecting this to ask one question -
How much ATF+4 does the 242 take when changing it out?
Thanks!
swataz is offline
post #13 of 14 Old 12-05-2008, 11:21 AM
99avant
wjjeeps.com has your answer.
|94 XJ|4.0|NP231|AW4|8.25 Trac Lock|Lotsa miles - SOLD
|99 WJ|4.7|242HD|Vari-lok|Upcountry+BB|DT8000|Dead as of 10/29/2009
If it aint broke, fix it till it is.
99avant is offline
post #14 of 14 Old 12-05-2008, 11:25 AM
swataz
Yes, indeed thanks. Looks like a little less than a quart and a half.
swataz is offline
ZJ transfer case abregar ZJ Grand Cherokee Forum 8 09-08-2007 08:44 AM
Transfer Case Death-Mobile ZJ Grand Cherokee Forum 2 05-05-2007 11:12 PM
Transfer Case HELP!!! TheCompound ZJ Grand Cherokee Forum 3 04-30-2006 08:59 PM
transfer case bill9000 ZJ Grand Cherokee Forum 23 10-04-2005 09:53 PM
Transfer Case? cherokeevince12 ZJ Grand Cherokee Forum 1 09-22-2005 05:55 PM
